Fan AC Motor adaptive use - problem
The discussion revolves around the overheating issues of a 60W A/C fan motor adapted to run two spindles at different RPMs. Suggestions include rewinding the motor with higher gauge copper wire, using higher temperature insulation, and ensuring proper airflow to cool the motor. Concerns are raised about the suitability of using shaded pole motors due to their heat generation and the importance of selecting a motor with adequate horsepower for the load. Additionally, the need for accurate load specifications and the potential risks of rewinding motors are highlighted. Ultimately, the motor's failure after brief load testing raises questions about its reliability and design suitability.
acmotor
We have adapted a 60W A/C Fan Motor, 1500 RPM to run two spindles one at 6000 RPM and the other at 500 RPM using pulley & belt. On continuous use the motor heats up excessively and a few fail.
Load is winding of threads from a Cone to a bobbin.
I need a few suggestion
i) Can rewinding the failed motors with a higher gauge copper wire solve the problem.
ii) How do you determine the load and create specification so that I can buy an appropriate motor capable of handling the load.
If the motor is properly designed and operating on the correct voltage, changing the wire size will make the motor run hotter.
Rewind the motor using a higher temperature insulation may be an option.
Blowing air over the present motor may be a solution.
Get motor with twice the horse power?
AC electric motors on the 60 W range are in an awkward wattage range which is too low for induction motors (usually 1/6 HP-125W) and up. The really low (and cheap) HP motors are called shaded pole, because a resistive copper strap surrounds part of the pole. These get very hot due to the resistive copper strap (needed to produce a starting torque). There are some permanent capacitor start-run ac motors that use capacitors rather than resistance to shift the ac phase. What are details of your motor?
LOWER gauge wire has LESS resistance. Fractional HP split phase motors use wire resistance to produce a phase shift in the starting coil, so changing wire gauge will change starting torque.
Start your search in the Grainger catalog:
http://www.grainger.com/Grainger/motors/ecatalog/N-bii?op=search
Bob S
Rewinding small motors is probably a bad idea because you'll violate the UL/CSA/VDE underwriting. Along with that, you'll have the cost issues.
When you're uncertain of the load, it's good to try an induction motor that's well defined. Run it at it's rated voltage, and check the shaft RPM and current draw.
Be careful of shaft loading. If you've got pulleys, but your motor is designed a simple fan, then you're likely to wear out the bearing prematurely. Ball bearings hold up to these radial loads better than the more common sleeve bearing.
You might go through this site for motors:
http://www.emersonmotors.com/products/ecatalog.htm
Further specification on the motor mentioned Temperature Rise < 75 K [I am unable to figure the temperature rating]
Also it uses a 2muF 450V capacitor
Onload Spec
A = 0.3 A
P = 60 W
RPM = 1350
230 V, 50 Hz Capacitor Motor
I tried running the motor with no load for 20 minutes and noted temperature 52 C [126 F]. Then used my hand to stop the shaft for a second or two and the motor failed. Is the motor faulty?
Thanks
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
49K
12K
