Fan Controller Circuit with Thermistor and R4 - TehnikService.net
The discussion focuses on connecting components in a fan controller circuit using an IC741 op-amp, specifically addressing the thermistor and resistor R4. The thermistor, which senses temperature, connects to the positive rail and one end of R4, while the other end of R4 connects to the negative rail and pin 2 of the IC741. This setup creates a voltage divider that influences the op-amp's output, controlling a transistor that operates the fan based on temperature changes. The transistor's collector connects to the fan and positive rail, while its emitter connects to the negative rail, allowing the fan to turn on or off as needed. Clear guidance on the connections and circuit layout is emphasized for effective assembly.
Pyro123
Your IC1 op amp thing is probably part of a package... look at your chip and most likely it is an 8-pin package.
Typically the pins count down on the left side and up on the right side if you have it the right way up.1 5
2 6
3 7
4 8
So look at the numbers on the pins.. and put the components in around them.
R4 runs from pin 2 to ground.
R3 should be connected at one point to where R4 is connected to the pin.
is R1 your thermistor?
thank you for replying R1 is the thermistor yeah but actually the 741 op amp is
36
45
everything is quite clear except for R4 and the thermistor..there's only 3 holes in the ground area in the layout 1 for the fan 2 for the capacitor and the 3rd should be for either the thermistor or R4 while both of them should be connected..should i dig another hole or something ?!
It is not clear exactly from what you've said. A good idea is probably to take a non-blurry, well lit photo of the circuit as it is at the moment. I should be able to see clearly on that and help you further :)
Sure, I would be happy to provide some guidance on how to connect the components to this fan controller circuit. Let's start with the thermistor and R4.
The thermistor is a temperature-sensitive resistor that is used to sense the temperature in the circuit. It works by changing its resistance in response to changes in temperature. In this fan controller circuit, the thermistor is used to measure the temperature of the air and adjust the speed of the fan accordingly.
To connect the thermistor to the circuit, you will need to first identify the two leads of the thermistor. One lead will be connected to the positive rail of the circuit, while the other will be connected to one end of R4. R4 is a potentiometer, which is a variable resistor that can be adjusted to change the resistance in the circuit. The other end of R4 will be connected to the negative rail of the circuit.
Next, you will need to connect a wire from the other end of R4 to pin 2 of the IC741. This pin is the inverting input of the operational amplifier, which is the main component of the circuit. The thermistor and R4 form a voltage divider circuit, which produces a varying voltage at pin 2 of the IC741 depending on the temperature.
The other two components in this circuit are the transistor and the fan. The transistor acts as a switch, turning the fan on or off depending on the voltage at pin 2 of the IC741. When the temperature rises, the voltage at pin 2 increases, causing the transistor to turn on and the fan to start spinning. When the temperature decreases, the voltage at pin 2 decreases, turning off the transistor and stopping the fan.
To connect the transistor to the circuit, you will need to connect its collector to the positive rail, its emitter to the negative rail, and its base to pin 3 of the IC741. Pin 3 is the output of the operational amplifier, and it will send a signal to the transistor to turn it on or off depending on the voltage at pin 2.
Finally, you will need to connect the fan to the collector of the transistor and the negative rail of the circuit. When the transistor is turned on, the fan will receive power and start spinning.
I hope this explanation helps you understand how to connect the components in this fan controller circuit. If you have any further questions, please let me know.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
