Calculating Exit Temperature of a Fan Given its CFM and Blade Size
To calculate the exit temperature of a fan given its CFM, blade diameter, and inlet temperature, additional factors such as atmospheric pressure may need to be considered. The fan's cooling effect is primarily due to evaporative cooling rather than a direct reduction in air temperature. When a fan operates, it can potentially raise room temperature by redistributing heat, especially if it is a ceiling fan. In specific scenarios, such as a fan blowing over a heated finned tube, the exit temperature can be influenced by the heat transfer characteristics of the system. Accurate calculations for exit temperature require knowledge of heat transfer through surrounding walls and the specific setup of the fan and heater.
math111
If I have a typical Fan with a given CFM or even the outside diameter of the blade can I find the exIting temperature? Is there a formula out there to determine the exit temp.
Assumptions:
The fan is located in the middle of a room so we are not mixing in different temperatures.
Given:
CFM, Dia of the blade, Inlet Temp.
Finding:
Exit Temperature
My thoughts.
1. Are my given conditions enough or will more factors be involved like pressure(atmpoheric[14.696 psi], etc..
2. Common sense would think it would make the exit temp lower due to air being blow when a fan cools you down when standing next to it.
Thanks.
Assumptions:
Given:
Finding:
Exit Temperature
My thoughts.
Thanks.
By doing some more research I found out the Fan will not cool a person but cause a affect by only drying/evaporate moisture from the persons skin making it feel cooler called the brush temperature. Also it says it might raise the temp of the room because heat rises and if its a ceiling fan it will blow the heat downward.
My problem is..
1. If I have an outside environment of 15 C
2. Inside environment of 30 Ft Dia. Circle = 2826 SF
3. Heater 4Kw with a Fan 860 CFM
what is the inside temperature going to be with this heater running.
You can't calculate the inside temperature without the heat transfer through the walls. The delta-T through the fan is 15 F, though...
ok some updates:
I have a fan going a Fan at 750 CFM blowing straight at a Finned Tube with a S/S enclosure with Holes in it directly in front of it.
'FAN'(750CFM)---> blowing over 'Finned Tube'(Fins and Tube@4kW)-->Blowing out of a S/S Heater guard with holes in it. I nned to find the exit temperature is my concern..?
It seems like a forced convection problem but I am not finidng the right information to solve it.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
