What is the time period for a rotating coil in a constant magnetic field?
A circular coil with a radius of 10 cm and 25 turns is rotating in a constant magnetic field of 2.4 T at a frequency of 50 Hz. The induced peak voltage can be calculated using the equation emf = -N * delta flux / delta t. The time period for one complete rotation is indeed 1/50 Hz, equating to 0.02 seconds. During this time, the magnetic flux through the coil remains periodic and returns to its initial value after each cycle. Understanding the periodic nature of the flux is crucial for calculating the induced voltage accurately.
chukie
A circular coil, with radius of 10 cm, and 25 turns, rotates in a constant magnetic field of
strength 2.4 T, with the axis of rotation perpendicular to the direction of the magnetic
field.
If the coil rotates at a frequency of 50 Hz, what is the induced peak voltage?
Okay so I know the equation to use is:
emf=-Ndelta flux/delta t
I know all the variables in the equation except for time. I was wondering how you calculate the time. Is it just 1/50Hz?
What is happening during that 1/50 of a second? The coil is being spun around an axis perpendicular to the external magnetic field. So what is going on with the flux through the coil? (The magnetic field strength is not changing at all!)
So is the change in time just 1/50=0.02s? The number seems a bit small to me.
Have you had calculus and used derivatives yet?
You would start by figuring out an expression for the flux as a function of time, then take the derivative.
No. After 0.02s (or 1 period), the flux will be exactly what it was at 0.00s. This is because the flux is a periodic function of time, with period 0.02s.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
