Faraday's Law: Induced Voltage and Current in a Loop with Resistance R
The discussion revolves around calculating the induced voltage and current in a loop with resistance R near an infinitely long wire carrying a time-varying current. The magnetic field generated by the wire is described by B = (μ₀I)/(2πr), which complicates the calculation of magnetic flux due to its dependence on distance r. Participants emphasize the need to integrate the magnetic field across the loop's area to accurately determine the magnetic flux. Clarifications about the variables used in the equations and the orientation of the loop relative to the wire are also discussed. Ultimately, the focus is on correctly applying Faraday's law to find the induced voltage and current.
horsewnoname
An infinitely long wire carries current I=I_0sin(wt). A distance a from this wire is an w by l loop with resistance R with induced voltage V and induced current i. Find the induced voltage and current in the loop.
Faraday's law is given by \varepsilon = \oint \mathbf{E}\cdot d\mathbf{l}=-\frac{d\phi }{dt}where \phi is the magnetic flux given by \int \boldsymbol{B}\cdot d\boldsymbol{s}.
I know that in order to find the voltage, I need to find the emf which is given by Faraday's law stated above. I pursue this by first coming up with an expression for the magnetic flux.
Although, to do this, I first need to know the magnetic field produced by the infinite wire. From memory (or by Ampere's law), I know this to be B=\frac{\mu _0I}{2\pi r}.
The problem I am having is that the magnetic field is a function of r which bothers me. When I use this magnetic field expression to determine the flux and then take the derivative with respect to time to yield the emf, the result is an expression for the voltage that varies with r which makes no sense. What am I forgetting?
I assume the ##w## in ##\text{sin}(wt)## is supposed to be different than the ##w## in the loop dimensions. I also assume that the loop is in the plane of the wire, is it or is it perpendicular to the wire?
horsewnoname said:
The problem I am having is that the magnetic field is a function of rrr which bothers me. When I use this magnetic field expression to determine the flux and then take the derivative with respect to time to yield the emf, the result is an expression for the voltage that varies with rrr which makes no sense. What am I forgetting?
You have to integrate ##\mathbf{B}## across the area of the loop in order to find ##\phi##.
Yes, of course - I just need to integrate the magnetic field over the dimensions of the loop so that I can get an expression for flux in terms of the given quantities. I feel foolish for not realizing this! And yes, you're assumptions were correct. The w in the sine should actually be an omega - that was my typo. Should I edit my question for posterity or will your stated assumptions suffice?
It should be fine since you have clarified it.
