FDQR ( Freshman Dream Quotient Rule)
JasMath33
I have been working with researching and writing a paper on the Freshman Dream Quotient Rule. This rule states
, and I was wondering if anyone can come up with an example of 2 functions which make this work.
I have looked at proofs and everything of this, but have not been able to come up with an example for my paper. For all I know, there may not be an example.
You can use the laws of derivatives to write:
(\frac{f}{g})' = \frac{f'}{g} - \frac{f g'}{g^2}
So you're trying to solve:
\frac{f'}{g} - \frac{f g'}{g^2} = \frac{f'}{g'}
or multiplying through by g^2 g':
f' g g' - f (g')^2 = f' g^2
We can separate the f and g be rewriting as;
f'(g g' - g^2) = f (g')^2 \Rightarrow \frac{f'}{f} = \frac{(g')^2}{g g' - g^2} = \frac{g'}{g} + \frac{g'}{g' - g}
So try picking some simple function for g and seeing if you can solve for f.
If f(x) = e^{kx}, g(x) = e^{lx} then <br /> \left(\frac{f}{g}\right)&#039; = (k - l)e^{(k-l)x}, \\<br /> \frac{f&#039;}{g&#039;} = \frac kl e^{(k-l)x}. These can be made equal by suitable choice of k and l.
Likes mfb
stevendaryl said:
\frac{(g&#039;)^2}{g g&#039; - g^2} = \frac{g&#039;}{g} + \frac{g&#039;}{g&#039; - g}
That looks like a freshman's dream on its own but it is correct.
That approach leads to a nice solution for some simple polynomial g.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
