Fesability of a micro LoJack type device.
A proposal for a glove equipped with a small transmitter antenna aims to achieve precise tracking of finger movements, potentially using a LoJack-like receiver. The challenge lies in maintaining accuracy to track movements as small as 1 mm, with existing solutions like IR LEDs and cameras proving unreliable due to occlusion. Suggestions include exploring millimeter wave systems that could be repurposed for passive tracking and utilizing contrasting colors or retro-reflective materials for better visibility. Alternatives such as image recognition for finger tracking are also mentioned, although they may involve more complexity. Overall, achieving this level of precise RF tracking may not be feasible within a reasonable budget.
Thick8
Hi All,
I would like to make a glove with a small transmitter antenna on the index finger. A small receiver similar to a LoJack device would track the finger. The device would need to be extremely accurate to follow small movement (1 mm?) of the transmitter. I’ve made a device that uses an IR LED, a 120 FPS camera, and the CameraMouse software but the LED is not always in view of the camera so the tracking is lost.
Is there any off the shelf components that come to mind? Is this level of precise RF tracking possible?
There are some millimeter wave systems that are normally designed to be used as active sensing devices. They may be programmable to be passive devices that might do what you want.
BoB
Edit: I don't know enough about this to say which ones are able to be used outside the intended purpose. Just google "millimeter wave soc" and you will get tons of devices.
The usual approach for that kind of tracking is to paint a target of a contrasting color on the glove and use ambient lighting. For testing you could use just some sticky tape of a contrasting color. A fancier approach is use retro-reflective paint or tape (3M makes both) and place illumination at the camera. Use a stripe around the finger if occlusion is a problem, or a pattern of dots to distinguish different rotations of the finger/hand.
There are other technologies that do not require line-of-sight to the hand but are a bit more complicated, some use just image recognition to find the fingers. A Google search gets over 300,000,000 hits. https://www.google.com/search?&q=video+tracking+of+hand+position
Cheers,
Tom
Not within reasonable budget I think.
Maybe you can use multiple cameras with different view angles and additional software to patch up data if one tracking is lost?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
