Solve Fick's Law Diffusion Problem with Mono-Energetic Neutron Sources
Therefore, you do not need to consider other variables. In summary, the neutron flux in the moderator is given by \Phi = S/Ʃa, which can be derived by assuming the diffusion equation to be steady-state and space independent.
afung
The problem of the homework states:
Mono-energetic sources of neutrons emitting S neutrons/cm3 are distributed throughout an infinite moderator with diffusion coefficient, D (cm), and absorption cross section Ʃa (cm-1)
Show that the neutron flux in the moderator is given by:
[itex]\Phi[/itex] = S/Ʃa
I know that the Diffusion equation is
dn/dt = S - Ʃa[itex]\Phi[/itex] + D[itex]\nabla[/itex]2[itex]\Phi[/itex]
For Steady-State the equation becomes
0= S - Ʃa[itex]\Phi[/itex] + D[itex]\nabla[/itex]2[itex]\Phi[/itex]
and [itex]\nabla[/itex]J =0 if space independent thus giving the following equation as
So, my question to this problem is can you assume the following diffusion equation to be steady state and space independent to get this:
[itex]\Phi[/itex] = S/Ʃa ? or do I need to consider other variables?
Yes, you can assume the diffusion equation to be steady-state and space independent to get the result that the neutron flux in the moderator is given by \Phi = S/Ʃa. This can be derived by rearranging the steady-state diffusion equation as follows: 0 = S - Ʃa\Phi + D\nabla2\Phi Rearranging, we get: \Phi = (S + D\nabla2\Phi) / Ʃa Since \nablaJ = 0 if space independent, this simplifies to: \Phi = S / Ʃa
1. What is Fick's Law and how does it relate to diffusion problems?
Fick's Law is a mathematical equation that describes the rate of diffusion of a substance in a medium. It states that the rate of diffusion is directly proportional to the concentration gradient and inversely proportional to the diffusion coefficient of the substance. In diffusion problems, Fick's Law is used to calculate the diffusion flux, or the amount of substance that diffuses through a unit area per unit time.
2. How does the presence of mono-energetic neutron sources affect the diffusion problem?
Mono-energetic neutron sources are sources that emit neutrons with a single, specific energy level. In diffusion problems, the presence of these sources can significantly impact the diffusion process, as the neutrons can interact with the diffusing substance and alter its concentration and diffusion flux. Therefore, when solving Fick's Law diffusion problems with mono-energetic neutron sources, it is important to consider their influence on the diffusion process.
3. Can Fick's Law be applied to all types of substances and mediums?
Yes, Fick's Law can be applied to all types of substances, as long as they are in a medium with a uniform concentration and diffusion coefficient. This law is commonly used to describe the diffusion of gases, liquids, and solids in various mediums, such as air, water, and solids.
4. What are the assumptions made when using Fick's Law to solve diffusion problems?
There are several assumptions made when using Fick's Law to solve diffusion problems, including: a constant diffusion coefficient, a uniform concentration gradient, a steady-state diffusion process, and no external forces or sources affecting the diffusion. These assumptions may not always hold true in real-world scenarios, but they provide a simplified model for solving diffusion problems.
5. How can the solution to a Fick's Law diffusion problem be used in practical applications?
The solution to a Fick's Law diffusion problem can be used to predict the diffusion flux and concentration profiles of a substance in a given medium. This information can be applied in practical applications such as drug delivery, air and water pollution control, and material coating processes. By understanding and controlling diffusion processes, we can improve and optimize various industrial and environmental processes.
  • Nuclear Engineering
  • Materials and Chemical Engineering
