Field due to ring charge at x-y axis.
The discussion focuses on determining the point on the positive z-axis where the electric field is strongest due to a uniformly charged ring in the xy-plane. The electric field expression derived is E = Qr / (b² + r²)^(3/2), with the maximum found at r = 2/(3√3)b², which was identified as incorrect due to dimensional issues. After further calculations, the revised potential maximum was suggested as r = ±b/√2, with the positive value being appropriate for the specified location. The participants confirmed the derivation of the electric field was correct, but emphasized the need for proper dimensional analysis in the final answer. The conversation highlights the importance of accuracy in both calculations and interpretations in physics problems.
Buffu
A charge ##Q## is distributed unifromly around a thin ring of radius ##b## which lies in ##xy## plane with its centre at the origin. Locate the point on the positive ##z## axis where the electric field is strongest ?
##\displaystyle d\vec E = {dQ \over b^2 + r^2 }\cos \alpha##. ##r## is the distance between the point, ##\alpha## is the angle between ##z## axis and the displacement vector , and the ring along ##z## axis.
##\displaystyle d\vec E = {\lambda dl \over b^2 + r^2 } \cos \alpha = d\vec E = {\lambda bd\theta \over b^2 + r^2 } \cos \alpha##.
Using ##\displaystyle \cos \alpha = {r \over \sqrt{b^2 + r^2}}##.
##\displaystyle E = {br\lambda \over (b^2 + r^2)^{3/2} } \int^{2\pi}_{0} d\theta = {2\pi br\lambda \over (b^2 + r^2)^{3/2} }##
Since ##\displaystyle \lambda = {Q\over 2\pi b}##,
I get,
##\displaystyle E = {Qr \over (b^2 + r^2)^{3/2}}##
Which has a maximum ##\displaystyle r = {2\over 3\sqrt{3}b^2}##.
Am I correct ?
The derivation of the electric field is correct. Your final answer is not. If b is the radius, your value for r has the wrong dimensions. It must proportional to b not to b-2.
Oh that was WA's mistake. I got lazy and let it calculate maxima. Is ## r = \pm b/ \sqrt{2}## correct ?
Where is b on the right side of the equation?
sorry.
I edited my post. Is the answer ##\pm b/\sqrt{2}## ?
I would pick the positive value because the problem specifies "on the positive z axis". Otherwise it's fine.
Likes Buffu
