Solving the Differential Eqn. for Field Lines of Vector Fn.
interested_learner
I'm not sure under what heading this belongs but I'm going to ask here:
Show that the field lines y = y(x) of a vector function
\mathbf F(x,y) = \mathbf i F_x(x,y)+\mathbf j F_y(x,y)
are solutions of the differential equation
\frac {dy} {dx} = \frac {F_y(x,y)} {F_x(x,y)}
Could someone suggest a way to get started on this one?
Yes. Use the fact that for a field line \vec{r}(t), we have the property that \vec{r}(t)\times \vec{F}(\vec{r}(t))=0. What do you get out of this property when the variable of parametrization t is simply the coordinate x?
Oops! My eyes just wandered on the sheet of paper on which I had sketched the solution to your problem and sudenly I realized "Hey, I this is not what I wrote in my post!"
The correct condition is that the derivative of r(t) is parallel to the field line:
\frac{d\vec{r}}{dt}(t)\times \vec{F}(\vec{r}(t))=0
Let me stress the geometric meaning of our problem.
For a function y=y(x) the inclination of the tangent \alpha_y
to the line representing the function in any point x is its derivative in that point:
\alpha_y = \frac {dy} {dx}
For a vector field F(x,y) the inclination of the vector \alpha_F in any point (x,y) is the ratio of its y and x components:
\alpha_F = \frac {F_y(x,y)} {F_x(x,y)}
Hence, your equation
can be seen as equating the two tangents:
\alpha_y = \alpha_F.
In other words, that equation states that the inclination of the line y(x) and the vector F(x,y) in the same point are equal. That's the definition of a field line.
Thanks. Quasar you had me scratching my head there for a while, but it makes sense now.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
