Field strength between two wires
The discussion revolves around calculating electric field strengths between conductors in various scenarios. For part (a), the electric field strength between two wires in a 230V power line is calculated to be 162 kV/m, which is correct. In part (b), the distance for a spark to jump at 16 kV is determined to be 16 mm, although there is confusion regarding the relevance of a 270 mm safety rule. Part (c) involves calculating the distance for a spark to jump from a damaged coffee machine conductor, yielding a result of 0.23 mm based on the peak voltage of 325V. The conversation highlights the importance of understanding electric fields and safety distances in electrical engineering contexts.
Maria H
I feel like a stupied girl. :(
It think it's not very hard, but I have to have the correct answear before i send it to my school.
We sometimes exposed to electric fields. To determine whether there is a risk of flashover is a rule of thumb which states that the sparks will switch if it is larger than the field strength of 1kV per mm, ie 1MV/m.
a) How big is the largest electric field between two leaders in a 230V-power line (peak voltage is 324V)? We assume that the distance between conductors is 2mm. Reply with a rounded integer. Answear in kV/m
b) If a person stands on a railway-wagon, an accident can happen if you come too close to the lead. If the voltage is 16kV, at which distance can a spark jump over and kill a person? The authority has a rules that says 270mm between the leaders at that voltage. Then you have gardening has objected to the management of moist air, etc.. Reply with a rounded integer.
c) If the insulation around a conductor to a coffee machine is damaged, at what distance from the leader can get a spark to turn over to a sink? Reply with two decimal places.
E=U/d
a) 324/0.002 =162000 =162kV/m I'm pretty right here :/
b) 16kV/1(kV/mm) = 16 mm
16mm according to the rule of thumb 1kV per mm. I don't see how I should take the rule of 270mm into considiration. It's obvioulsy a better distans..
c) 0.230V/1(kV/mm) = 0.23mm
Cheers/Maria
(a) and (b) look good, though I don't understand the remark that "gardening has objected to the management of moist air, etc.." I have no idea what that means or how it enters into question (b).
For (c), if it's a 230 V line then the peak voltage is actually 325V. Otherwise, you have the right idea.
