Fill factor of a photovoltaic cell
  • Thread starter Thread starter wisdom32
    Cell Photovoltaic
To identify the fill factor of a photovoltaic cell, the maximum power is calculated using the formula (Vmp x Jmp) divided by the short-circuit current (Isc) and open-circuit voltage (Voc). Proper circuit setup requires a voltmeter connected in parallel to the solar cell and an ammeter in series. Short-circuit current refers to the maximum current the cell can produce, while open-circuit voltage is the maximum voltage without load. Readings from the voltmeter and ammeter can indeed be used to plot a current versus voltage graph. Simple experiments can yield maximum power results, but high-end equipment may enhance accuracy.
wisdom32
I basically want to identify the fill-factor of a photo voltaic cell by calculating the ratio of maximum power (Vmp x Jmp) divided by the short-circuit current (Isc) and open-circuit voltage (Voc) in light current density.
1. How am i suppose to set up the circuit, should a voltmeter be parallel to the solar cell and an ammeter be serial to the circuit ?
2. What is meant by short-circuit current and open-circuit voltage ?
3. Are the readings on the voltmeter and ammeter be used to plot a graph of current against voltage ?
Thanks!
alright, it seems that no one seems to know. but i just want to know that whether the maximum power of a photovoltaic cell can be obtained thru simple experiments or does it require some very high end equipments
hey I am working on the same problem in my research, have you figured out a solution yet?
