Final velocity, incomplete equation (answear included)
A space vehicle traveling at 1200 m/s separates into two sections with masses of 865 kg and 2010 kg, with the heavier section moving 120 m/s slower than the lighter one. The equation derived for the final velocities is based on the conservation of momentum, leading to the conclusion that the final velocity of the lighter section is 1284 m/s and the heavier section is 1164 m/s. The discussion emphasizes the importance of understanding what each variable represents in the context of the problem. Participants are encouraged to revisit their equations and clarify their understanding of the conservation laws involved. The conversation highlights the need for a solid grasp of physics principles to solve such problems effectively.
bcoolplayer
A space vehicle traveling at a velocity of 1200ms -1 separates by a controlled explosion into two sections of mass 865kg and 2010 kg. The two parts carry on in the same direction with the heavier rear section moving 120 ms -1 slower than the lighter front section. Determine the final velocity of each section.
i got as far as this on the equation however I am stuck
(865+2010)*1200=865*V+(V-120)*2010=2875*…
we have been told that V=1284m/s
and heavier body velocity=1164m/s
Well, you're almost there. You've got an equation that can be solved for V:
ok that good 2 know, and where 2 go from here
Ask yourself what V represents (after all, you wrote the equation!). Compare with what the problem is asking you to find out.
im really stuck, i don't know please give me a hint
Go back over your derivation of the equation. What was V for?
velocity
Which velocity?
the travling velocity
Of what?
the space vehicle
bcoolplayer said:
the space vehicle
Surely that's what the "1200" is on the left hand side of the equation?
yees
bcoolplayer said:
yees
So then, what is V the velocity of?
i aint got a clue, is it for the heavier body velocity
You need to be sure if you are to understand how to do these sorts of problems.
What physical law allowed you to write the equation in the first place?
dllamberts principle
Not quite. There's a particular conservation law involved here.
