Find:2 Non-isomorphic groups of order n squared. help?
  • Thread starter Thread starter assman
    Groups
Two non-isomorphic groups of order n squared are identified as Z_n x Z_n and Z_(n^2). Z_n x Z_n is not cyclic, while Z_(n^2) is cyclic, highlighting their non-isomorphic nature. The Klein four-group and Z_4 are also mentioned as examples of non-isomorphic groups of order 2^2. The distinction in their structures can be understood through their dimensions as vector spaces. This discussion clarifies the concept of non-isomorphic groups in group theory.
assman
i think that Zn X Zn is one.
Can you help me find another.
Thanks
Isomorphic to what?
nonisomorphic means not isomorphic to each other, doesn't it? like the klein 4-group & Z_4 both have order 2^2 but are nonisomorphic
since K_4 = Z_2 x Z_2 i conjecture off the cuff that the 2 nonisomorphic groups with order n^2 would be Z_n x Z_n and Z_(n^2)
If you mean non-isomorphic to each other, then you can take Z_(n^2) and Z_n x Z_n, for example (under addition).
In response to the above post: Indeed, those work, since Z_(n^2) is cyclic but Z_n x Z_n is not (you can see this alternatively in terms of vector spaces: dim(Z_(n^2)) = 1 but dim(Z_n x Z_n) = 2)
