Fractals of rational dimension and fractals of integral powers
The discussion explores the generalizations of fractals with nonzero rational dimensions M/N, focusing on their geometric properties compared to those with integral dimensions. It raises questions about the relationship between a fractal of non-integral dimension F and one of dimension GF, where G is a nonzero integer. The geometry of extending a fractal dimension F to G axes is also examined, particularly in relation to integer dimensional spaces. The Serpinski gasket is mentioned, with conflicting claims about its fractal dimension, highlighting the complexity of defining fractal dimensions. The conversation emphasizes the need for clarity in understanding fractal dimensions and their geometric implications.
Loren Booda
What generalizations can be made concerning fractals of nonzero rational dimensions M/N (where M and N are nonzero integers)?
How does a fractal of non-integral dimension F compare geometrically to a fractal of dimension GF, where G is a nonzero integer?
Mathematics news on Phys.org
In the first paragraph, I was concerned with a fractal space that could be raised to the integer Nth power to obtain a whole number dimensional space.
Similarly, in the second paragraph, I wondered about the geometry of an "axis" of fractal dimension F extended to G axes to produce a GF fractal dimensional space, or moreso, comparing the geometry of int[GF] dimensional spaces of int[GF] axes for G=1, 2, 3... .
Believe the Serpinski gasket has a fractal dimension of exactly two.
no - triangle has a dimension of 1.58. Carpet has a dimension of 1.89.
If its dimension was 2 it wouln't be a fractal.
Cheers,
ron.
Can't help with the earlier Q.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
