Find a BASIS for L(S) -The Image of S
  • Thread starter Thread starter murielg
    Basis Image
To find a basis for the subspace S defined by the plane equation x1 + 3x2 + x3 = 0, two linearly independent vectors v1 and v2 that span the plane must be identified. The discussion clarifies that any two points on the plane can define a line, but to establish a basis, one must express the plane in terms of linear combinations of vectors. The transformation L(v1) and L(v2) is necessary to find the basis for the image L(S), not just S. The participants emphasize the importance of correctly interpreting the problem and ensuring clarity in communication. Understanding the distinction between S and L(S) is crucial for solving the homework problem effectively.
murielg
[PLAIN]http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs574.ash2/149609_293915114994_507054994_1176494_3477051_n.jpg
Ok so I know that this plane goes thru the origim
I guess to find the two column vectors that span S, say v1 and v2
so i need to find two points on that plane that are not in the same line, right?
and then do L(v1) and L(v2) to find the basis for S ?
The equation of the plane is x1 + 3x2 + x3 = 0.
You can find a basis for the plane this way:
x1 = -3x2 - x3
x2 = x2
x3 = ...x3
If you squint at that awhile, you might see that any vector in the plane is a linear combination of two vectors. Those vectors are your basis for S.
That's not possible. You can run a line through any two points on a plane.
No, calculate L(v1) and L(v2) to find a basis for L(S). You should already have a basis for S from the work above.
Thanks for your answer.
I need to find the basis for L(S) not just S
Sorry i made a mstake when writing my explanation, but it's rigth there in the image i attached.
Thanks
Please reread my last reply...
JUST DID! sorry i read it too fast the first time
THANK YOU! :)
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
