Find Acceleration with an angle
  • Thread starter Thread starter MusicalAyame0
    Acceleration Angle
A clerk pulls a box of cans with a force of 185.0 N at a 25.0-degree angle, with the box weighing 35.0 kg and a coefficient of kinetic friction of 0.450. To find the acceleration, it's essential to draw a force diagram to visualize the forces acting on the box. The vertical component of the pulling force offsets the weight, affecting the normal force. The net force, calculated by considering the friction opposing the horizontal component of the pulling force, divided by the mass, yields the acceleration. Understanding these dynamics is crucial for solving the problem effectively.
MusicalAyame0
1. A clerk moves a box of cans down an aisle by pulling on a strap attached to the box. The clerk pulls with a force of 185.0 N at an angle of 25.0 degrees with the floor. The box has a mass of 35.0 kg, and the coefficient of kinetic friction is 0.450. Find the Acceleration of the box.
Find the accerlation.
3. I have no idea how to do this. please help!
Welcome to PF.
Draw a force diagram. The normal force of the weight looks like it will be offset by the vertical up component of the force.
So that leaves the net normal force down times the coefficient of friction opposing the horizontal component of the force. That net force divided by the mass gives you the acceleration.
Thanks!
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
