Find an expression for the electric field for the area r<R
The discussion revolves around a non-uniform spherical charge distribution defined by a specific charge density equation, where the goal is to find an expression for the electric field within the region where the radius is less than the main volume radius (r < R). Participants are exploring concepts related to electric fields, charge distributions, and Gauss's Law.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Gauss's Law and the calculation of enclosed charge using integrals. There are attempts to relate the electric field to the charge distribution and to clarify the nature of the charge density. Some participants question the assumptions made about the charge distribution and the integration limits.
The discussion is active, with participants sharing their attempts and reasoning. Some guidance has been offered regarding the interpretation of the charge distribution and the application of Gauss's Law. There is a recognition of the complexity of the problem, and multiple interpretations are being explored.
Participants note that the charge density is not uniform and varies with radius, which complicates the calculations. There is also mention of the need to clarify the constants involved in the charge density equation.
Engels
One ,non uniform but spherical in symmetry distribution of charge has charge density which is given by the following equations
ρ=ρο(1-r/R) when r< R and ρ=0 when r>R, ρ0=3Q/πr^3 and it is constant
a) show that the total charge included by this distribution is equal to Q
b)show that for r>R the electric field is the same that occurs as if it comes from a point charge
c)find an expression for the electric field for the area r<R
the equations i used was gauss law and Qenc= integral pdV
i hope u understand i don't to write yet in latex
I solved a and b and i can't think about c
i know that the desired expression is E=(p0r/12ε0)(4-3r/R)
i tried the following path without success
[tex]\int E dA[/tex]=Qenc/ε0 but Qenc=[tex]\int p Dv[/tex] therefore
[tex]\int E dA[/tex] equals [tex]\int p Dv[/tex] i figure out how dV is so change it with the equal dr expression so i did for dA..i idi the math math but no result equal the solution i wrote above...
any help is good cause i have tests in the university in few days :P
Edit: Sorry I misread your post...you're asking for (c).
The electric field inside a hollow thin shell of uniformly distributed charge is 0. For a position r from the center, note that it can be considered to be contained within a shell of inner radius r and outer radius R; this shell has a thickness and varying charge density, but you could also look at it as several infinitesimally thin shells of different but still uniform charge densities piled on top of each other. Also note that at the same time as being contained within a thick shell, it can also be considered to be right outside a charged sphere of radius r.
Thanx for the reply but it doesn't help to much..
The charge distribution is not uniform inside the volume and it behaves according to this equation
ρ=ρ0(1-r/R) p= charge density R=radius of the main volume and r= radius of the gauss surface.. and ρ0=3Q/πR^3 and it is constant
I need to find an expression for the electric field for r<R(inside the main volume) E(r)..I Looked at the solution and the desired equation is E=(p0r/12ε0)(4-3r/R)
I can't get to this equation...i tried to do the following maths [tex]\int E dA[/tex] = Qenc/ε0 and Qenc= [tex]\int p dV[/tex] and compine those two
That's how you should do it. How far did you get doing each integral?
i said dA=8πrdr and dV=4πr^2dr and r from 0 to R and did the maths..u can try it but u can't result to the desire equation...i took E as constant in the integral and solved by E
can u think of anything different ?
Try to visualize it like this. Take an arbitrary value r < R; this would imply the electric field at a spherical surface (surface G) with radius r inside the spherical charge distribution mentioned. So you have an electric field coming from the charge distribution beyond surface G and from the charge distribution within surface G. What my other post was stating was that the electric field from beyond surface G is 0 N/C; so the electric field at surface G (in other words, at a radius R) is due primarily to the charge distribution within surface G (meaning the charge distribution up to a radius r). So what you'd have to do is use Gauss's Law to calculate the electric field due to the charge distribution at a radius r --- The other main difference in (c) from (a) and (b) is that in (a) and (b) the charge distribution is Q...however, since you're only looking at the charge distribution up to a radius r, you'll have to evaluate a different value for the charge in part (c).
To begin with dA is not 8πr dr. Element dA is on the surface of the sphere where the radius is constant. Also, you say that the constant in the charge distribution is ρ0=3Qπ/r3. I think it should be ρ0=3Qπ/R3, otherwise it is not a constant. Maybe the r3 in the denominator confused you.
Do each side of Gauss's Law separately,
[tex]\int \vec{E} \cdot \vec{dA} = ?[/tex]
[tex]\int \rho dV = ?[/tex]
and tell us what you get for each. It would be easier to help if you show what you did.
Ok boys i solved..i took ,like before, those two ,indefinite now, integrals and solved them to find E
my mistake was that before i took those two definite integrals from 0 to R
when i find the time i will post the entire problem with the solution so others can see...
this was my first experience in this site and i found it very useful and nice :)
excellent...and u guys rulez..
12K
