Find entropy where the temperature is lower than the saturated temperature
To find the entropy and enthalpy at a pressure of 100 bar and a temperature of 260°C, the dryness fraction (x) must be determined, but there are two unknowns in the equations. The availability equation requires values for enthalpy (h) and entropy (s), which depend on the saturation properties at the given pressure. The saturation temperature at 100 bar is 311°C, indicating that the system is subcooled. To compute the necessary values for s and h, using the ASME steam tables is recommended for accurate results. Understanding these properties is essential for calculating availability in thermodynamic systems.
civic_67
my starting of system is 100 bar and 260 degree C. the saturation temperature for 100 bar is 311 degree C. so in order to find my enthalpy and entropy, i need to find x, dryness fraction. but my equation have 2 unknowns. how do I calculate availability?
availability = (h-h0) -T0(s-s0)
s = sf + xsfg
have 2 unknowns. how do i compute s and h in order to compute availability?
ASME or Keenan & Keyes Steam tables?
ASME steam tables
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
