Find equation in slope-intercept form
  • Thread starter Thread starter gillgill
    Form
The discussion focuses on finding the slope-intercept form of equations for various lines based on given points and conditions. For the line through (-2, 3/4) and (2/3, 5/2), the proposed equation y=21/32x+33/16 is questioned for accuracy. A horizontal line through (8,7) is confirmed to be y=7, indicating that the y-value remains constant. The equation for a line with an x-intercept of -2/3 and perpendicular to 2x-y=4 is debated, with the suggestion of y=-1/2x+1/3 being challenged due to incorrect y-intercept calculations. Overall, the importance of verifying equations by substituting points back into them is emphasized.
gillgill
find equation in slope-intercept form for line through (-2, 3/4) and (2/3, 5/2)
does y=21/32x+33/16 seem right?
Horizontal, through (8,7)
is it y=7??
find equation in slope-intercept form for line with x-intercept -2/3 and perpendicular to 2x-y=4
does y=-1/2x+1/3 right?
You can test your first equation by substituting the points back into your equation.
The second equation y = 7 implies that for all x values the y value are 7. Does this seem right to you?
Your last equation cannot be right since the y-intercept is not the given one!
On this one, I got what you did, except the y-intercept of mine was negative. When I substituted -2/3 for x in y=-1/2x, i got 0=1/3 + b, therefore moving it to the other side would yield a negative...
ic...thanks...
