Calculating Kinetic Friction for Skidding Motorcycle
To calculate the force of kinetic friction for a motorcycle skidding on dry concrete, the weight of the motorcycle is given as 2350 N and the coefficient of friction is 0.7. The correct calculation for the force of kinetic friction is 2000 N, which can be derived using the formula: friction force = coefficient of friction × normal force. A participant in the discussion initially calculated the friction force as 1645 N and is seeking clarification on the mistake made in their calculation. Accurate understanding of the formula and values is crucial for determining the correct force of kinetic friction.
rrosa522
A biker and his motorcycle have a weight of 2350 N [down]. Calculate the force of kinetic friction for the rubber tires and dry concrete if the motorcycle skids. (Coefficient of friction is 0.7)
my answer i got was 1645 but the correct answer is 2000
If you tell us how you got your answer, someone will probably be glad to tell you where your mistake is.
