Find Limit of Sum Homework: H(2n)-H(n)
  • Thread starter Thread starter nonaa
    Limit Sum
nonaa
\lim_{n\to\infty}\frac{\ln 2 - \sum_{k=1}^{n}\frac{1}{k+n}}{\ln 2 - \sum_{k=1}^{2n}\frac{(-1)^{k-1}}{k}}=?
H(2n)-H(n)= \sum_{k=1}^{n}\frac{1}{k+n}
I tried to use that \ln 2 = \sum^{\infty}_{k=1} \frac{(-1)^{k+1}}{k}, but with no success. Can you help me, please?
Any ideas?
The sum term in the numerator approaches ln(2) as n goes to infinity since the sum can be manipulated into resembling a Riemann sum (via a regular n equal subdivisions partition of [0,1]). Also what exactly is H?
yes, I already found that, but how does it help us?
H - harmonic series: H(n)=\sum_{k=1}^{n}\frac{1}{k}; It's not part of the problem, just thought it can be useful...
You can write complicated expressions for the numerator and denominator in terms of the digamma function. Which means you can apply l'Hopital. What can do with that depends on how much you know about the digamma functions. I don't know much. Just playing with the numbers seems to show the absolute value of that ratio approaches a limit. But since the numerator is an alternating series approximation the sign keeps flipping.
Sadly, I know nothing about the digamma function :(
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
