How to Find the Number of Nuclei of Element A at Time t0?
  • Thread starter utkarshakash
  • Tags
    Nuclei
In summary: If it helps, imagine plotting a curve (a graph) of N vs. t. We don't know exactly what that plot looks like yet. But imagine for a moment that at some point in that plot, N (represented on the vertical axis) is a minimum at time t (on the horizontal axis). So we don't know everything about what the graph looks like, but one thing we do know is that at that point, the slope of the curve would be dN/dt.
utkarshakash
Nuclei of radioactive element A are produced at rate t^2 (where t is time) at any time t. The element A has decay constant λ. Let N be the number of nuclei of element A at any time t. At time t=t0, N is minimum. Then N at t0 is what?
[itex]N(t) = kt^2 - \lambda t [/itex]
For N to be minimum, dN/dt = 0. But doing this gives me the wrong answer.
If "The element A has decay constant λ" then the decay should be [itex]- \lambda N[/itex], not "[itex]-\lambda t[/itex]".
Hi utkarshakash!
Your expression for N(t) seems to be incorrect. From the first statement, can you write down an expression for dN/dt?
Pranav-Arora said:
Hi utkarshakash!
[itex]\dfrac{dN}{dt} = kt^2 - \lambda N [/itex]
That looks very good to me. :approve:
There is just one thing though about the k constant. The problem statement said, "Nuclei of radioactive element A are produced at rate t^2" I'm wondering if you meant to write
"produced at rate k t2" or if k = 1. Putting the k in there makes the answer more general, so there isn't anything wrong with doing so. I just don't know if the problem statement wants you to assume that k = 1 or not.
Whatever the case, moving on:
So if we want to find out where N(t) is a minimum or maximum at some point, we set what equal to zero so we can find it?
Should I find N by solving this differential equation and then differentiate it and set it zero or just set kt^2-λN equal to 0? Personally I don't feel setting the latter equal to 0 would be reasonable as it would still contain 'N' in it.
So we don't know everything about what the graph looks like, but one thing we do know is what the slope of the curve is. The slope of the curve is dN/dt. That's all that dN/dt is: the slope of the curve.
So if the curve is smooth (let's assume that it is), what does the slope of the curve have to be at the point of the minimum?
It doesn't really matter if N and t are in the equation for dN/dt insofar that dN/dt is the slope. dN/dt is the slope whether it's a function of a few variables or many variables. It is what it is. (And it's fortunate here that N is in the equation, because otherwise you wouldn't be able to solve for it at the point where the slope is zero.)
[Edit: To be clear, at this point we don't really know what the slope of N vs. t strictly as a function of t. Nor do we know what the slope is solely as a function of N either. But we do know the slope if we were given both N and t -- and more importantly -- if we know what the slope is, we have an immediate relationship between N and t at that particular slope; and that's enough to solve the problem. :wink:]
Setting dN/dt = 0 gives [itex]N = k t_0 ^2 / \lambda[/itex]. But this is not the correct answer.
Did you try ##k = 1##, i.e. ##\displaystyle N_{min} = \frac{t_0^2}{\lambda}##?
If that's not the correct answer either, then are you sure the question is not asking how many nuclei are present initially, i.e. at ##t = 0##? It is actually possible to calculate this in terms of ##\lambda## and ##t_0##.
Yes, but it does not matches any of the options given. The question asks the number of nuclei of element A at t=t0
What are the options? If too unwieldy for Latex, scan and attach. In fact, if you're doing that, include the entire question.
[itex]
\dfrac{2t_0 - \lambda t_0 ^2}{\lambda ^2} \\
\dfrac{t_0 - \lambda t_0 ^2}{\lambda ^2} \\
\dfrac{2t_0 + \lambda t_0 ^2}{\lambda} \\
\dfrac{t_0 - \lambda t_0 ^2}{\lambda}
[/itex]
utkarshakash said:
[itex]
[/itex]
Wow. OK. I'm not getting any of these either.
Going purely by dimensional analysis, I'd say the answer they expect is one of the first two. Even dimensional analysis is difficult here because the constant you called ##k## is not dimensionless (it has dimensions of ##T^{-3}##). But because they assigned a numerical value to it, there are "hidden" dimensions in the constant(s) of the final expression.
Sorry, can't help you further, I'm afraid. Either I'm missing something or the question is wrong.
A quick update: I got confirmation from another Homework Helper that he's getting the same result.
The question as it is posed looks incorrect. However, it would be good if you could check with your Prof/TA and post back here. Apart from our satisfaction at getting a resolution, it's nice to close the loop for students who search for this topic in future.
There is a high probability that this question may be incorrect. But currently it is not possible for me to contact my teachers and I do not have a solution to this question. However, if I manage to get solution I will post it as soon as possible. But for now it is better to end this thread.
Hi utkarshakash!
This problem is from one of the past test papers of your coaching institute. At the first sight, it hit me that I have seen the problem somewhere. Seeing at the arousing confusion, I tried searching the past papers and found the exact same problem. The solution goes along these lines:
$$\frac{dN}{dt}=t^2-\lambda N$$
For ##\frac{dN}{dt}## to be minimum: ##\frac{d^2N}{dt^2}=0##.
$$\Rightarrow \frac{d^2N}{dt^2}=2t-\lambda \frac{dN}{dt}=2t-\lambda(t^2-\lambda N)=0$$
$$\Rightarrow N=\frac{2t_0-\lambda t_0^2}{\lambda^2}$$
Honestly, I don't see what the authors meant here. Clearly, the problem statement mentions that N is minimum at ##t=t_0## but they seem to be minimising the rate instead.
Pranav-Arora said:
Hi utkarshakash!
Ah, thanks for the clarification. The question is indeed incorrect. I've seen quite a few of the papers from coaching institutes in India. While most of the questions are good and challenging, there are some which are poorly stated, or simply wrong, as in this case. Caveat emptor.
Pranav-Arora said:
Hi utkarshakash!
Hey. Thanks for posting the solution. You are correct. This question is from FULL TEST V. I also can't understand why they have minimised the rate of change of N.
Can you please post the solution of this:
https://www.physicsforums.com/showthread.php?t=736847&page=1
This is also from the same test paper.
Pranav-Arora said:
Hi utkarshakash!
And in fact, Bruce pointed out (in the HH forum) that even this expression is incorrect!
It should go:
$$2t_0-\lambda (t_0^2 - \lambda N)=0$$
$$\frac{2t_0}{\lambda} = t_0^2 - \lambda N$$
$$\lambda N = t_0^2 - \frac{2t_0}{\lambda}$$
$$N = \frac{t_0^2 - \frac{2t_0}{\lambda}}{\lambda}= \frac{\lambda t_0^2 - 2t_0}{\lambda^2}$$
Which is not one of the provided options either. Sorry, I hadn't checked it myself until now.
Bruce was also the one who helped corroborate my earlier work, I'm acknowledging him now.
It should go:
I also didn't notice it. I thank Bruce for pointing out the mistake. I think this question is useless as the question itself is wrongly formulated and the correct option is also missing.
1. How do you calculate the number of nuclei in a sample?
The number of nuclei in a sample can be calculated by dividing the mass of the sample by the atomic mass of the nucleus and then multiplying it by Avogadro's number (6.022 x 10^23).
2. What is Avogadro's number?
Avogadro's number is a constant that represents the number of particles (atoms, molecules, etc.) in one mole of a substance. It is equal to 6.022 x 10^23.
3. How is the atomic mass of a nucleus determined?
The atomic mass of a nucleus is determined by adding together the number of protons and neutrons in the nucleus. This is also known as the mass number of an atom.
4. What is the unit for measuring the number of nuclei?
The unit for measuring the number of nuclei is the mole (mol). It is a unit of measurement in the International System of Units (SI) and is defined as the amount of a substance that contains the same number of particles as there are atoms in 12 grams of carbon-12.
5. Is it possible to determine the exact number of nuclei in a sample?
No, it is not possible to determine the exact number of nuclei in a sample due to the uncertainty principle in quantum mechanics. The number of particles in a given sample can only be determined up to a certain probability, but not with absolute certainty.
