Find parallel vector component
In summary, the conversation discusses finding the position vector A of a car, measured from a fixed point O, into parallel components along OB and OC. The homework equations involve using the projection of vector A onto OC, which can be found by multiplying the magnitude of vector A by the unit vector of OC. The solution involves finding the angle of triangle AOC and using it to compute the parallel component along OC. However, the book provides a different answer than the solution given by the individual. A clarification is made regarding the projection of vector B along A.
blackandyello
Resolve the position vector A of the car (measured from fixed point O)
into components parallel to OB and OC.
Figure: http://screensnapr.com/e/4D2OAz.png
Projection of vector A to OC = |A| * |unit vector OC| * unit vector
my solution for finding the component parallel to OC is by finding the angle of triangle AOC, then use that angle to compute for parallel component at OC. my answer ended up to be the same 3500m. but the book says, 2570m along OC.
A.B = ABCosθ is the projection of vector A along B.
But if you take [itex]B = A[/itex] then you find the projection of [itex]A[/itex] along [itex]A[/itex] is [itex]A^2[/itex]
oh sorry. I mean B cosθ is the projection of B along A.
To find the parallel component of the position vector A, we can use the projection formula: projection of vector A to OC = |A| * |unit vector OC| * cosθ, where θ is the angle between vector A and OC.
To find the angle θ, we can use the dot product formula: A · OC = |A| * |OC| * cosθ. Rearranging this formula, we get cosθ = (A · OC) / (|A| * |OC|).
Substituting the values given in the figure, we get cosθ = (3000 * 1000 + 4000 * (-3000)) / (5000 * 4000) = -0.2. Therefore, θ = arccos(-0.2) = 101.54°.
Now, plugging this value of θ into the projection formula, we get projection of A to OC = 5000 * 1000 * cos(101.54°) = 2570m.
Therefore, the parallel component of A along OC is 2570m. This differs from the book's answer of 3500m, which may be due to rounding errors or a different method used to find the angle θ.
1. What is a parallel vector component?
A parallel vector component is a component of a vector that is parallel to a given reference vector. It is the amount of the reference vector that is in the same direction as the given vector.
2. How do you find the parallel vector component of a vector?
To find the parallel vector component of a vector, you first need to determine the reference vector. Then, you can use the formula: parallel component = (reference vector dot given vector) / (magnitude of reference vector).
3. What is the significance of finding the parallel vector component?
Finding the parallel vector component can be useful in many applications, such as physics, engineering, and computer graphics. It allows us to break down a vector into its components and understand its direction and magnitude more clearly.
4. Can a vector have more than one parallel component?
No, a vector can only have one parallel component with respect to a given reference vector. However, it is possible for a vector to have multiple components that are parallel to different reference vectors.
5. Are there any special cases when finding the parallel vector component?
Yes, there are a few special cases to consider when finding the parallel vector component. If the given vector is parallel to the reference vector, then the parallel component will be equal to the given vector itself. If the given vector is perpendicular to the reference vector, then the parallel component will be equal to 0. Lastly, if the given vector is antiparallel to the reference vector, then the parallel component will be equal to the negative of the given vector.
