Find points on a plane at(0,0,0) 2x+3y+yz=12
  • Thread starter Thread starter Unemployed
    Plane Points
12 replies · 2K views
Unemployed
d^2=x^2 +y^2-(2x-3y-12)/y
fx=2x-(4 (2x-3y-12)/y)
fxx= 2-8/y
Fy 2y-(2*3*(2x-3y-12)/y)
Fyy= (4y+3)/y^2
I am getting round numbers to plug back in. Totally wrong approach?
Find points on a plane (2x+3y+yz=12) at 0,0,0
Find points on a plane 2x+3y+yz=12 at (0,0,0)
d^2=x^2+y^2+((2x+3y-12)/-y)^2
My calculation: fx= 2xy-8x+12y-48/y
Looked on a derivative calculator: (2xy^2+8X+12y-48/)y^2
My calc:
fy= (^33-2X-3Y+12)/y^2
The fyy and fxx get convoluted assuming i did the first derivatives correctly. Then the d-test for saddle. Need a comprehensive explanation of this example. Thanks
This is not the equation of a plane. Are you trying to find points on the plane that is tangent to the surface 2x+3y+yz=12 at (0,0,0)?
The problem with that interpretation of what you wrote is that (0, 0, 0) is not a point on this surface.
My calc:
How about starting with the exact wording of this problem.
How is it not a plane? I graphed on a 3-D graphing calculator (using what i got as z) and it was a plane, it was twisted but a plane. Planes usually take the formula a(x1-xo)+b(y1-yo)+c(z1-z0)=Constant
The onlyway that this equation is incorrect is it was supposed to be 2x+3y+4z=12
Would that make more sense?
There is no twist in a plane.
Sort of. It should be a(x - x0) + b(y - y0) + c(z - z0) = Constant.
Well, at least that's actually a plane. The problem is that it doesn't go through (0, 0, 0), which is pretty easy to check.
What is the actual wording of the problem you're trying to solve?
These are problems given in notes as HW made up as the professor goes along rather than straight out of the book. You are right in that I am not sure in what the hell he is asking.
I assume the plane is 2x+3y+4z=12
Then it says:
Find the point on the plane and the point (0,0,0)?
Following the example:
Classify the critical points and max, min,saddle or test fails
x+y+z=3
at (1,2,3)
Does it say "Find the point on the plane 2x+ 3y+ 4z= 12 closest to (0, 0, 0)"?
It that were the problem, you would want to find the line through (0, 0, 0) perpendicular to 2x+ 3y+ 4z= 12 and find where that line crosses the plane.
x+y+z=3
at (1,2,3)
(1, 2, 3) is not a point on the plane x + y + z = 3.
it still does say find point on the plane 2x+3y+4z+12 and the point (0,0,0)
But I am guessing he meant find the point closest to 0,0,0
The prior example x+y+z=3
at point (1,2,3) does show use of the perpendicular. Thanks for the help deciphering
To find the point on x+ y+ z= 3, closest to (1, 2, 3), note that the vector <1, 1, 1> is normal to the plane and so x= 1+ t, y= 2+ t, z= 3+ t is perpendicular to the plane. That point intersects the plane when (1+ t)+ (2+ t)+ (3+ t)= 6+ 3t= 3 so 3t= -3 and t= -1.
That is the point x= 1- 1= 0, y= 2- 1= 1, z= 3- 1= 2 or (0, 1, 2).
So minimizing the square of the distance (which automatically minimizes the distance), you have d2 = f(x, y) = x2 + y2 + (3 - x/2 - 3y/4)2.
Now you can find your two partial derivatives and set them to zero to find the x, y, and z coordinates of the point on the plane that is closest to the origin.
This works but is not the way I would do it. For planes (and linear problems in general) it is not necessary use Calculus. Of course, if the problem were your original 2x+ 3y+ yz= 12, which is not a plane, you would have to use Calculus but apparently that was a mistype for 2x+ 3y+ 4z= 12.
