MHB Solving for Real Numbers $a$ and $b$ in $f(x)=\dfrac{1}{ax+b}$
The discussion revolves around finding real numbers \( a \) and \( b \) for the function \( f(x) = \frac{1}{ax+b} \) such that there are three distinct real numbers \( x_1, x_2, x_3 \) satisfying \( f(x_1) = x_2 \), \( f(x_2) = x_3 \), and \( f(x_3) = x_1 \). A key insight is that the condition \( a + b^2 = 0 \) is necessary for the existence of such distinct solutions. The participants also derived a quadratic equation from the function's properties and discussed the implications of its discriminant for ensuring distinct solutions. Graphical analysis was suggested to visualize the conditions under which the function behaves as required. The conclusion emphasizes the importance of the derived condition for solving the problem effectively.
anemone
MHB
POTW Director
Hi MHB,
This problem has given me a very hard time because I have exhausted all the methods that I know to figure out a way to find for the values for both a and b but no, there must be a trick to this problem and I admit that it is a question that is out of my reach...
Could you show me how to attack this problem, please?
Thanks in advance.:)
Problem:
For real numbers $a$ and $b$ define $f(x)=\dfrac{1}{ax+b}$. For which $a$ and $b$ are there three distinct real numbers $x_1, x_2, x_3$ such that $f(x_1)=x_2$, $f(x_2)=x_3$ and $f(x_3)=x_1$?
Mathematics news on Phys.org
anemone said:
Hi MHB,
Problem:
some one may come with a neat method but one solution I suggest is
f(f(f(x) = x
now f(f(1/(ax+b)) = x
anemone said:
Hi MHB,
Problem:
With trivial substitions You should arrive to the second order equation...
$\displaystyle a\ (a+b)\ x_{1}^{2} + (a + 2\ b - a\ b)\ x_{1} + b - 1 =0\ (1)$
... and the condition for real solution of Your system is to be $\ge 0$ the discriminant of (1)... if the solutions are also 'distinct' is of course a different problem...
Kind regards
$\chi$ $\sigma$
I prefer to call the numbers $x,\ y,\ z$, so that $f(x)=y$, $f(y) = z$ and $f(z)= x$. Then $y = \dfrac1{ax+b}$, $$z = \frac1{\frac a{ax+b} + b} = \frac{ax+b}{abx+b+b^2},$$ $$ x = \frac1{\frac{a^2x+ab}{abx+b+b^2} + b} = \frac{abx+b+b^2}{(a^2+ab^2)x + 2ab + b^2}.$$ Therefore $$(a^2+ab^2)x^2 + (2ab + b^2)x = abx+b+b^2$$, which simplifies to $a(a+b^2)x^2 + b(a+b^2)x - (a+b^2) = 0.$ Divide through by $a+b^2$ to get $ax^2+bx-1 = 0.$ But now we are in trouble, because if $ax^2+bx-1 = 0$ then (dividing through by $x$) $\frac1x = ax+b$, which means that $x = \frac1{ax+b} = y$, contradicting the requirement that $x$ and $y$ should be distinct.
Looking back to see what went wrong, you notice (if you did not do so at the time) that we divided that quadratic equation by the constant $a+b^2$ without considering the possibility that $a+b^2=0$. That is the only thing that can rescue the problem from having no solution, so it looks as though the answer to the question is that $a$ and $b$ must satisfy the condition $a+b^2=0$. That is certainly a necessary condition, and I leave it to you to check that it is also sufficient for the problem to have a solution.
Kind regards
$\chi$ $\sigma$
f(f(f(x) = x
Thank you to both of you, kaliprasad and chisigma for the help!
Good answer, with an excellent explanation! Mr. Opalg, I can't tell you how thankful that I am for all your help!
I realized now that for any given equation, in order to keep it balance, not only we can add/subtract the same quantity from both sides of the equation, we can also take square root to it, square it, divide the whole equation by some quantity which isn't zero (such as the situation in this instance), I am so happy that I learned something so valuable today! Thank you so so much, Opalg!
Btw,:) I used the graph of the function $f(x)=\dfrac{1}{ax+b}=\dfrac{1}{-b^2x+b}$ below to check that the condition $a+b^2=0$ suggests that there are three distinct real numbers $x_1, x_2, x_3$ such that $f(x_1)=x_2$, $f(x_2)=x_3$ and $f(x_3)=x_1$:
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
