Find smallest value of k in this equation
  • Thread starter Thread starter thereddevils
    Value
The discussion focuses on finding the smallest value of k in the equations n^(5/3) = m^(7/2) and nm = p^k, where m, n, p, and k are positive whole numbers greater than 1. The analysis reveals that k must be a multiple of 31 for m and n to remain whole numbers, leading to the conclusion that the smallest valid k is 31. The reasoning includes ensuring that expressions like p^(10k/31) yield integers, which further supports k = 31 as the only feasible solution. Ultimately, the answer is determined to be option C, 31. This conclusion is reached through a combination of algebraic manipulation and consideration of integer constraints.
thereddevils
For these equations m,n,p,k are positive whole numbers greater than 1 .
n^(5/3)=m^(7/2)
nm=p^k
What is the smallest value that k can be?
(A) 6
(B) 11
(C) 31
(D) 41
some hints ?
try to get n in terms of m. Then see what k has to be such that p^k = nm
that leaves me with p^k=m^(31/10)
and i am not told which is greater , p or m
you now get m = p^(10k/31) which means p^(10k/31) must be a whole number > 1.
So what does that mean for (10k/31)?
erm 10k/31>0 ?
I would suspect that 10k/31 must be an integer so that p^(10k/31) is also an integer. I don't have any proof for this, but someone else might. As such it means that 10k must be a multiple of 31. Does that make sense?
EDIT: sorry this is incorrect.
If we are simply trying to satisfy the equation for the smallest k,
just solve it like this
m^(31/10) = p^k => m^(31/10k) = p
So if k = 6, we just need some m such that its 60th root is a whole number.
So let m = 2^60 or anything like that.
we have that n = m^(21/10) so n is also a whole number.
well i have another thought on it ,
m=p^(10k/31)
For m is a positive whole number, 10k/31 must be an positive integer and p is known to be a positive whole number.
Therefore ,k must be a multiple of 31 where the smallest is 31 itself. SO the answer is obviously C
10k/31 does not need to be a positive integer.
Consider 9^(1/2)
Consider 9^(1/2)
k is known to be a positive whole number from the question and none of the values of k for
1<k<31 is able to make the indices either a whole number or square roots , cube roots ,...until 31.
