Find Speed of Gayle & Brother on Sled After Descent from Hill
  • Thread starter Thread starter VelvetRebel
    Speed
Gayle starts at a speed of 4.23 m/s on a sled at rest and descends a vertical distance of 5.03 m before her brother joins her. To find their speed at the bottom of a total 14.1 m drop, conservation of momentum and energy principles must be applied. The initial speed before her brother hops on can be calculated using energy conservation, which accounts for the change in potential energy as she descends. After determining her speed prior to the collision, the combined speed can be calculated using momentum conservation, treating the situation as inelastic. Understanding these concepts is essential for solving the problem effectively.
VelvetRebel
Gayle runs at a speed of 4.23 m/s and dives on a sled, which is initially at rest on the top of a frictionless snow-covered hill. After she has descended a vertical distance of 5.03 m, her brother, who is initially at rest, hops on her back and together they continue down the hill. What is their speed at the bottom of the hill if the total vertical drop is 14.1 m? Gayle's mass is 46.8 kg, the sled has a mass of 4.95 kg and her brother has a mass of 26.9 kg.
I have no idea where to start. I don't understand on where to incorporate the height into the problem. All I know is that you have to apply the conservation of momentum somewhere. I'm also assuming this is a totally inelastic situation.
Yes, you will use conservation of momentum but determining the speeds upon "collision" will require conservation of energy to determine her/their speeds at various heights on the mountain. You need to determine her speed right before her little brother jumps on, and she will increase her speed due to her change in potential from the top.
Oh wow. That was really simple. Thanks for the help.
