Find the current induced in a wire loop by a nearby current
The discussion revolves around calculating the induced current in a wire loop (ABCD) due to a nearby current-carrying wire. Participants clarify that the induced electromotive force (emf) can be determined using the formula emf = L * B * v, where B is the magnetic flux density from the long wire. The conversation highlights that only certain segments of the loop (AB and CD) experience induced emf, while BC and DA do not, due to their orientation relative to the magnetic field and motion. The Lorentz force is discussed as a key factor in understanding the behavior of charges within the loop. Ultimately, the focus is on correctly applying the principles of electromagnetism to find the induced current in the circuit.
Helly123
When the circuit moves creates magnetic force that moves the some charges in the wire and that is a current.
That is what i thought.
F = Q.v B sin theta
B = ( permeability Of vacuum* I)/(2pi.r)
But how to find the I?
Thank you very much
Please type your problem statement, list of all varables, knowns/unknowns and relevant equations. The picture is illegible.
Likes Helly123
You don't have to. All the answers are given in terms of ##I##, not as numbers.
BvU said:
Please type your prob;lem statement, list of all varables, knowns/unknowns and relevant equations. The picture is illegible.
I am sorry. I should have checked it. now, I have replaced the picture. please have a look
Same picture, same sharpness, though...:eek:
ok, I = V/R
the Resistance = R
is that anything to do with B?
there is circuit ABCD shaped as a square next to a wire
circuit description :
with AB (vertical) = 2a
BC (horizontal) = 2b
the center is O.
O to B is b ( B to C = 2b)
what is the current flow in ABCD circuit, when the circuit reached r away from wire to its center O?
(the circuit move with speed v to right, AB still parallel to wire)
the question says B (Magnetic flux density) to be negligible
You should distinguish the ##I## in the long wire from the currrent in the ABCD loop. Still can't read the picture...[edit] better now...
And you need a relevant equation for V, the emf induced in the loop
V = emf = electromotive force = L.B.v
emf = L. ##\frac{µ0 * I}{2 \pi r}##.v
emf = 2a. v. ##\frac{µ0 * I}{2 \pi (r - b)}##​
I ind = Emf/R = av ## \frac{µ0 * I}{\pi R (r - b)}##
And where is that emf ? In AB, BC, CD or DA ?
it is on AB
What about the others ?
Can you please elaborate? Because i don't understand
You found an emf on AB. Does any of the other sides of the square also have an emf ?
I don't really understand the question, lol. Is it a circuit moves from a wire in magnetic field? If yes, there is B. By right hand rule the B goes into the page. Magnetic force goes to the left, as velocity goes to right.
Usually it is a wire moving in magnetic field and induce a current. That is why i don't get this question..
There really are four connected wires in a square loop. You looked at only one and stopped looking !
Yes. So in emf = Blv sin theta
I think the theta refers to angle between movement and magnetic field.. so, for BC and AD what is the theta? And which direction is magnetic field ..
Keep going...
And check here
Emf BC = bv##\frac{µ0.I}{\pi (R-b)}##
Emf CD = av##\frac{µ0.I}{\pi (R+b)}##
Emf AD = bv##\frac{µ0.I}{\pi (R-b)}##
No sir. Only one out of three is (almost :rolleyes:) correct :biggrin:.
You want to look carefully at the here link in #20.
And in fact, also at the keep going one...
Likes Helly123
The only one right is CD and the answer is B? But i don't understand why. Why there is no voltage in BC and AD?
BC and DA, that is. They correspond to the middle picture where no emf is induced along the wire.
You're very quick to pick the B answer and not A, but I suppose you worked it out properly ?
(did you understand my 'almost' in #22 ?)
The way I remember things: I just start with the Lorentz force
BvU said:
To keep a long story short I add over a Thousand words:View attachment 168089
Big picture, big importance (imho)
Both pictures:
  • Positive ##x## direction is to the right
  • Magnetic field is down. Consider that the positive ##y## direction :smile:
  • Big arrowheads: in the ##x\, y## plane
  • Smaller arrowheads in the ##\hat z = \hat x \times \hat y## direction (a very simple cross product)
  • The coordinate system is right-handed
  • The Lorentz force is ##\vec F = q\, \left (\vec E + \vec v \times \vec B \right )##
  • There is no E field
  • Right hand rule: in ##\vec a \times \vec b = \vec c##
    a thumb
    b index
    c middle -- points in the direction of c​
  • Corkscrew rule: in ##\vec a \times \vec b = \vec c##
    turn ##\vec a## over the smallest angle towards ##\vec b## : Corkscrew goes in the direction of c​
Top picture:
  • We see a wire carrying current to the right. Current is moving charge. Moving charge has a "velocity".
  • We consider mobile positive charges in the wire :smile:
  • The Lorentz force is ##\vec F = q\, \vec v \times \vec B ##
  • All moving positive charges in the wire feel this Lorentz force
  • Together they "push" in the direction of ##\vec v \times \vec B ##
  • mutatis mutandis for moving negative charges: they move in the negative x-direction and the resulting Lorentz force points in exactly the same direction (- q x -v = +q x +v)
Bottom picture:
  • We see a wire being dragged in the positive ##z## direction with a velocity ##\vec v##.
  • Together they "push" in the direction of ##\vec v \times \vec B ##, which is the negative ##x## direction
  • This "push" is an electromagnetic potential (emf) that can cause a current.
Likes Helly123
Such a new thing for me to know.. thank you so much. So, the velocity direction is opposed to force?
Why only positive charges feel Lorenzt force?
Is the moving of charges produce Lorentz force or the positive charges moves to fight Lorentz force?
What is ## I## in the wire refers to? To current in straight wire? And we look for current in square circuit?
BC and DA have force but no voltage since it moves parallel to v. AB and CD moves perpendicular to v. And have voltage no force.
The 'almost' was because of the sign. It is opposite to that induced in AB.
#25:
No. Velocity ##\vec v## and magnetic field ##\vec B##, are both perpendicular to the resulting force ##F##.
Helly123 said:
Why only positive charges feel Lorentz force?
Not what I meant. What I meant is: one doesn't want to confuse oneself unnecessarily by looking at negatively charged moving charge carriers. So if a current ##\vec I## is given, work with positive charge carriers moving in that direction.
The Lorentz force ##\ \vec F = q(\vec E + \vec v\times \vec B)\ ## works on ALL charges, negative (q<0) or positive (q>0)
(:smile: also on neutral charges (q=0) )
Motion of charge produces a magnetic field.
Positive charges move under the influence of a Lorentz force -- if they can. In a conductor (a wire), the positive charge carriers generally are not free to move. Electrons, the negative charge carriers, can move and thereby generate an emf.
I think I understand what you are trying to say here (correct me if I miss): Lorentz force on CD pushes electrons down and positive ions up. Positive ions can't move, electrons can. They don't move without limits (they don't pile up because they repel each other, and there is a resistance)​
#26: The exercise in post 1 gives a current ##I## in the long wire and asks for the current in loop ABCD; with resistance ##R## given, that is equivalent to asking for the emf divided by ##R##.
#27:
They do not. Their net charge is 0.
Helly123 said:
AB and CD move perpendicular to v
No. Their direction of motion is the direction of ##\vec v##. Their orientation is perpendicular to ##\vec V##.
Likes Helly123
What makes the sign different? Since, B, v still the same?
And where the 'b' comes from the options?
What makes the wire have magnetic force?
Why the question said that the magnetic flux density is negligible?
  • #31
Going round the loop, emf = VAB+VCD = VAB-VDC
Do the math and post...
The free charge carriers in the wire can move under the influence of the force. The Lorentz force is the underlying phenomenon. It's extremely important in physics. As to the 'why?' of the Lorentz force: you can dig deeper into the fundamentals of electrodynamics, but a 'why?'question is ultimately not answerable. Physicists restrain themselves and search for the 'how?'.
It did not. It only said you don't have to take into account the magnetic field due to the current in the loop. The whole exercise can also be done by determining the magnetic flux through the loop (the flux due to ##I## in the long wire ) and applying Faraday's law.
Likes Helly123
  • #32
Thanks for the explanation. Why going in loop make different sign?
  • #33
BvU said:
#22:
#25:
#27:
What is their orientation? From high potensial to low?
  • #34
#33: Sorry, I meant a lower case velocity vector ##\vec v##
All wires are in the plane of the paper. Orientation of section AB is perpendicular to ##\vec v##. Same with CD. But both move with velocity vector ##\vec v##.
Magnetic field from ##\vec I## is into the paper. Vector cross product ##\ \vec v \times \vec B \ ## is upwards (same direction as ##\vec I\;##), both in AB and in DC. AB is stronger (closer to ##\vec I\;##) so netto* the emf in the loop causes a clockwise (ABCD) current.
*Going round the loop means add up
VAB + VBC + VCD + VDA =
VAB + 0 + VCD + 0 = VAB - VDC
Likes Helly123
  • #35
Yes. But why Vcd become negative?
  • #36
You mean VDC = - VCD ? Are you asking about the behavour of a potential difference ?
  • #37
Yes. Please
  • #38
$$V_{DC} = V_D - V_C \\
V_{CD} = V_C - V_D \\
V_D - V_C = -\left ( V_C-V_D \right) \Rightarrow V_{DC} = - V_{CD}$$ :biggrin:
Likes Helly123
  • #39
Make a diagram indicating polarities to see that the induced voltages push in the same direction, therefore in opposite directions in the loop
Likes Helly123
  • #40
What is polarities diagram?
  • #41
Current CD is different direction than AB
But why the way we calculate current different than circuit connected to battery or any voltage source?
  • #42
Right
We do it exactly the same way:
[edited: this way it corresponds to the picture in post #1]
Likes Helly123
  • #43
I cannot put it as solved. Why there is no current in BC and DA?
Emf = Blv sin theta
  • #44
What is ##\theta## ?
There is current, of course (or else there would be an accumulation of charge and you can't have that if there is a conductor in between).
  • #45
Theta is between v and length or the wire?
If yes, 90 degree is for AB and CD
And 0 for BC and DA
Because the B going into the page and v to left
  • #46
Yes, in a way. Check the links in #24. The underlying expression is the Lorentz force:$$\vec F = q\, \left (\vec E + \vec v \times \vec B \right )$$so in BC the emf is indeed perpendicular to the direction of the wire.
Helly123 said:
and v to left
I have a distinct memory that ##\vec v## is to the right, but PF doesn't want to show the picture in #1 at this moment :smile:
Likes Helly123
