Find the difference in mass between the charged objects.
The discussion revolves around calculating the mass difference between two charged objects, A and B, both initially neutral but charged by induction with equal and opposite charges of -4.6 x 10^-6 C and +4.6 x 10^-6 C, respectively. Participants attempted to find the number of electrons involved in the charge and the corresponding mass but faced challenges in their calculations. Additional unrelated questions about electric fields and charge distribution among multiple spheres were also raised, but the focus remained on the mass difference inquiry. The thread concluded with a reminder to seek help only when truly stuck, emphasizing the importance of using the forum effectively. Ultimately, the thread was locked due to concerns about the nature of the questions being asked.
WhoElseoftheBDC
Object A is metallic and electrically neutral. It is charged by induction so that it acquires a charge of -4.6 x 10-6 C. Object B is identical to object A and is also electrically neutral. It is charged by induction so that it acquires a charge of +4.6 x 10-6 C. Find the difference in mass between the charged objects.
i tried dividing the charge by the charge of one electron/proton which is 1.602x10-9 and then multiplying that by the mass of one electron/proton but i still get the wrong answer!
How many protons or electrons does it take to make the 4.6uC of charge? What is the mass of a proton and of an electron?
What is the normal electrical charge carrier?
Where did the proton come from?
If C is coulomb, then how many electrons is that?
i got that one solved by myself guys sorry haha but i do have another...
A tiny ball (mass = 0.015 kg) carries a charge of -20 µC. What electric field (magnitude and direction) is needed to cause the ball to float above the ground?
You must show your work in order for us to help you (PF rules). What equations apply to your question?
just solved that one too haha...maybe if i keep postin em ill keep gettin em...heres another one...with more detail lolConsider three identical metal spheres, A, B, and C. Sphere A carries a charge of -6q. Sphere B carries a charge of +5q. Sphere C carries no net charge. Spheres A and B are touched together and then separated. Sphere C is then touched to sphere A and separated from it. Lastly, sphere C is touched to sphere B and separated from it.
what is the charge on sphere c?
this one seems simple but I've tried everything from -1, 1, -5 and 5 i don't understand how to find the answer
Well, I'm not inclined to help you much more in this thread if you are able to figure out your homework problems on your own. Please consider the PF as a place you go for advanced help, not basic help for your homework. There's a finite amount of bandwidth in any real system, right? You've just wasted some bandwidth, and colored your use of the PF in the future.
Please only post questions that you really are having trouble with. In the real world (after you graduate), time is money. Please only post for help in the future when you are really stuck.
Thread locked.
