Find the domain of continuity of this function
chrisy2012
x*sin(sqrt(x^2+y^2))/sqrt(x^2+y^2)
find the domain of continuity
none
I found the domain, which is x^2+y^2 > 0 and since x^2 >= 0 and y^2 >= 0 therefore the domain is (-inf,0) (0,inf)
but the professor then asked for the "domain of continuity" and asked us to "carefully explain", i don't know how that is different from the domain i found.
none
That's not the domain. As you have it, the domain is all of the real line except 0. Your function has a domain that is two-dimensional; i.e., the domain is actually some subset of R2.
sorry my mistake, What i meant to say is that the domain is the xy plane except for at point (0,0). But still, how is that different from "domain of continuity"?
I'm not familiar with that term. Your function is defined at and continuous at every point in the plane, except (0, 0). I'm guessing that, in this case, the domain of continuity is the same as the domain.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
