Find the eigenvalues and eigenvectors for the matrix
tomeatworld
Find the eigenvalues and eigenvectors for the matrix [{13,5},{2,4}]
None
Well eigenvalues is easy, and turn out to be 14 and 3.
So using eigenvalue 3, the two equations 10x1 + 5x2=0 and 2x1 + x2=0. Using these, I assumed the eigenvector to be [1,-2] but after putting it into Wolfram (or mathematica) it gives out the vector should be [-1,2]. Is there a difference? How should you discern between the two if not and where have I gone wrong if there is?
None
Assuming your work is correct, there is no difference between <1, -2> and <-1, 2> as far as being eigenvectors. Each of these vectors is the -1 multiple of the other, so they are both in the same eigenspace, a subspace of dimension 1 (a line) in R2.
Great. So do programs like mathematica choose them at random or is there a reason it chose <-1,2> over <1,-2>?
Ok, thanks for the help!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
