Find the electric field and force at a point in 3d space
This discussion focuses on calculating the electric field and force at a specific point in 3D space, particularly in relation to Problem 2.1. The key approach involves simplifying the Coulomb constant to a single constant, k = 1/(4πε₀), and analyzing the contributions of individual charges Q1 and Q2 separately. The user successfully determined Q1 as -8.323 nC and Q2 as -45 nC, while also seeking verification for their answer to Problem 2.2, which they believe to be 40 nC. The conversation highlights the importance of component-wise analysis of electric field vectors.
  • Understanding of Coulomb's Law and electric fields
  • Familiarity with vector addition in physics
  • Knowledge of the concept of electric charge in nanocoulombs (nC)
  • Basic proficiency in solving physics problems involving multiple charges
  • Study the derivation and application of the Coulomb constant in electric field calculations
  • Learn how to perform vector component analysis for electric fields
  • Explore the implications of charge interactions in 3D space
  • Review problem-solving strategies for similar physics homework problems
Students studying electromagnetism, physics educators, and anyone needing assistance with electric field calculations in multi-charge systems.
DODGEVIPER13
Uploaded Problem 2.1
Etotal=Eq1+eq2
On problem 2.1 I need quite a bit of help here. I am not really sure how to approach this I have done some work but it is highly incorrect. I hand wrote my solution, so I will upload that too.
  • Homework 2.pdf
    Homework 2.pdf
Here is my redo I saw a problem in the book that looked kinda close so i tried to follow it but it really wast that close in the end
Your second attempt is better as it is taking the vectors into account, but I think you're trying to do too much at once.
Start by reducing the Coulomb constant to a single constant: ##k = \frac{1}{4 \pi \epsilon_o}##. That way you don't need to drag the whole thing through the calculations.
Next, Deal with one charge at a time. Find the field at the point in question due to Q2 alone, since it's a fixed feature. Call that E2.
Then find the contribution by Q1, leaving just the Q1 as a variable (so you'll end up with some vector constant, say D, multiplied by Q1 to yield the vector components of the E-field due to Q1 at the point in question). Call that E1.
At this point you should be able to deal component-wise with the various E vectors to address the requirements of the questions.
well I figured it out but thanks for the reply I get Q1=-8.323 nC and Q1=-45nC. Well I didnt figure it out but I saw a solution I understood
hey can you check my 2.2 answer though I feel that it is right I get 40nC. Sorry my upload wasnt super clear!
I don't follow your working, but answer looks okay to me.
Thanks I have moved onto 2.3 and broke it off onto another post as you has said earlier. Thanks again
  • · Replies 26 ·
  • · Replies 50 ·
  • · Replies 16 ·
