Find the equation of the line by using vectors
  • Thread starter Thread starter TheMathNoob
    Line Vectors
The discussion focuses on finding the equation of a line using vectors a and b, specifically in relation to the triangle formed by vector addition. The solution presented is generally correct, but it emphasizes that there should be no constraints on the parameter t, as a line consists of an infinite number of points. It is suggested that the equation can be simplified to t(a→ + b→), allowing t to represent any value. The original poster acknowledges a misunderstanding regarding the necessity of boundaries to align with the triangle concept. Overall, the conversation clarifies the correct approach to expressing the line equation in vector form.
TheMathNoob
I have to find the equation of the line by using any vector a and b in a way that the line fits the triangle generated by vector addition. If you don't understand my statement, look at my attached file. You will understand what I mean by triangle. Is my solution right?
Essentially, it is correct.
However - There is no requirement for such constraint for t. Remember, you are writing an equation for a line; an infinite number of points are possible.
Further, you could just write the second term on the right, as t(a+b), and t can take an infinite number of values, corresponding to an infinite number of points on the line.
thanks I wasn't actually clear on the fact that the boundaries are necessary to fit the idea of triangle.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
