Find the final Celsius temperature of the aluminum and water
The final Celsius temperature of the aluminum and water system is calculated to be 31.96°C using the equation T_f = (m_water*C_water*T_water + m_aluminum*C_aluminum*T_aluminum) / (m_water*C_water + m_aluminum*C_aluminum). The entropy change for the aluminum pan is ΔS_Al = -602.549 J/K, calculated using ΔS = Q/T with the specific heat and mass values provided. The same method applies to calculate the entropy change for water and the total entropy change of the system.
  • Understanding of thermodynamics principles, specifically heat transfer.
  • Familiarity with specific heat capacity calculations.
  • Knowledge of entropy and its calculation using ΔS = Q/T.
  • Basic algebra for solving equations involving multiple variables.
  • Study the concept of thermal equilibrium in closed systems.
  • Learn about the first law of thermodynamics and its applications in heat transfer problems.
  • Explore advanced entropy calculations in multi-phase systems.
  • Investigate the effects of varying specific heats on temperature changes in mixed substances.
Students studying thermodynamics, physics educators, and anyone involved in heat transfer calculations in engineering or scientific research.
gamobigz
A 2.3kg aluminum pan at 135° is plunged into 3.0kg of water at 15°. The specific heat of aluminum is 900 J/(kg K).
Part A
Find the final Celsius temperature of the aluminum and water.
T_f = °Celsius
Part B
Find the entropy change of the aluminum pan.
ΔS_Al = J/K
Part C
Find the entropy change of the water.
ΔS_H20 = J/K
Part D
Find the entropy change in the system of particles consisting of all the particles in the aluminum plus all the particles in the water.
ΔS = J/K
Q=mCΔT
ΔS=Q/T
So my first couple attempts was that we use the equation Q=mC(T_f-T_i)
other related equations i know is DeltaS=Q/T but, how can i find the temperature final of both Water and aluminum.
I tried setting it up like this
m_water*C_water(T_f-T-i) + m_aluminum*C_aluminum(T_f-T_i) = Q_total
but i don't know how to get anything done from there.
Please help me with the first part and i should be able to most of it done on my own.
I found the answer to the first two. And the first two will eventually help you with the rest.
attached in this form is a file showing the integration for part b.
Part A
Q_water+Qaluminum=0
m_waterC_water(T_f-T_water)+m_aluminumC_aluminum(T_f-T_aluminum)=0
using distribution from algebra and algebraically solving for T_F,
T_f=(m_waterC_waterT_water+m_aluminumCaluminumT_aluminum)/(m_waterC_water+m_aluminumC_aluminum)
you get Tf = 31.96 degrees Celsius.
Where, if your values were,
m_aluminum=2.3kg
T_aluminum=135 degrees Celsius
C_aluminum=900J/kg*k
m_water=3kg
T_water=15 degrees celsius
C_water=4190J/kg*kPart B
=(2.3kg)(900J/kg*k)ln((31.96+273)/(135+273))=-602.549J/K
Part C
use the same format, as b, but with different mass and specific heat, and T_i values, T_f is the same.
Part D is the sum of part B and C.
