Find the final speed of the heavier particle
In summary: If v1= 9.81- 2v2, then mv1= m(9.81- 2v2)= 9.81m- 2mv2. But that is exactly what we have in the first equation so we can substitute 9.81m- 2mv2 for mv1 in the second equation:(1/2)m (9.81- 2v2)2+ (1/2)(2m) v22= 144.36.m (9.81- 2v2)2+ (2m) v22= 288.72m (96.2361- 39.24v2+ 4
Aerospace
39
Two particles, of masses m and 3m, are moving toward each other along the x-axix with the same initial speeds of 9.81 m/s. Mass m is traveling to the left, and mass 3m is traveling to the right. They undergo a head-on elastic collision and each rebounds along the same line as it approached.
Find the final speed of the heavier particle.
Not sure how to go about it, if someone could please help!
Try this...
In any elastic collision, the linear Momentum and Kinetic Energy are conserved. Thus if v = final velocity of 3m, then
v = [(2*m)/m+3m]*9.81 = 4.905 m/s
Hope u have ur problem solved...
Sridhar
Nope, that answers wrong.
I also tried it another way
I used ur equation plus 9.81(3m - m / m + 3m)
and that came out as 9.81 which is, again, also wrong.
I'm wondering if it has something to do with the signs since one is traveling to the left and the other to the right...
As sridhar_n said: in an elastic collision, kinetic energy is preserved (total kinetic energy stays the same). In any collision in which there are not "external" forces, total momentum stays the same.
You are given a mass, m (kg? Since this is in terms of m, it doesn't really matter), moving to the left with speed 9.81 m/s.
Taking speed to the left to be negative, the mass has momentum
-9.81m kg. meters/sec. and kinetic energy (1/2)m (-9.81)2= 48.12m Joules (Notice that the negative speed doesn't matter. Kinetic energy is a scalar, not a vector so this doesn't have a "direction").
The mass 2m kg. is moving to the right at 9.81 m/s. It has momentum (2m)(9.81)= 19.62m kg m/s and kinetic energy (1/2)(2m)(9.81)2= 96.24m Joules.
The total momentum before the collision is 19.62m-9.81m= 9.81m kg m/s and the total kinetic energy is 48.12m+ 96.24= 144.36 Joules.
Call the speed of the mass m after the collision v1 and the speed of the mass 2m v2. The total momentum after the collision is mv1+ 2mv2 and the total kinetic energy after the collision is (1/2)m v12+ (1/2)(2m) v22. Since both total momentum and total kinetic energy are the same before and after collision, we have
mv1+ 2mv2= 9.81m and
(1/2)m v12+ (1/2)(2m) v22= 144.36.
Notice that the "m" terms cancel in both equation.
v1+ 2v2= 9.81 so v1= 9.81- 2v2.
Substitute that into the energy equation, solve to find v2 and then find v1.
Note that you will be using the quadratic solution to find v2.
You can always tell if you have done it correctly because one of your two solutions to the quadratic will always be the original velocity.
i don't know what to do with the m's when i put v1 into the energy equation...
Did you miss this from my earlier post?
"mv1+ 2mv2= 9.81m and
Notice that the "m" terms cancel in both equations.
v1+ 2v2= 9.81 so v1= 9.81- 2v2."
Related to Find the final speed of the heavier particle
What is the formula to calculate final speed of the heavier particle?
The formula to calculate the final speed of the heavier particle is Vf = (m1 * Vi1 + m2 * Vi2) / (m1 + m2), where Vf is the final velocity, m1 and m2 are the masses of the two particles, and Vi1 and Vi2 are the initial velocities of the two particles.
How do you determine the initial velocities of the particles?
The initial velocities of the particles can be determined by using the conservation of momentum principle, which states that the total momentum of a system remains constant before and after a collision. This means that the sum of the initial momentums of the two particles before the collision is equal to the sum of their final momentums after the collision.
Can the final speed of the heavier particle be greater than the initial speed of the lighter particle?
Yes, it is possible for the final speed of the heavier particle to be greater than the initial speed of the lighter particle. This can happen if the lighter particle has a lower mass and a higher initial velocity than the heavier particle.
What factors can affect the final speed of the heavier particle?
The final speed of the heavier particle can be affected by various factors such as the masses and initial velocities of both particles, the angle and direction of collision, and external forces acting on the particles during the collision.
Is there a difference in the final speed of the heavier particle between elastic and inelastic collisions?
Yes, there is a difference in the final speed of the heavier particle between elastic and inelastic collisions. In elastic collisions, the final speed of the heavier particle will be greater than in inelastic collisions due to the conservation of kinetic energy principle.
