Find the magnitude and direction of each vector
To find the magnitude and direction of vectors A, B, and C, the angle should be measured counter-clockwise from the positive x-axis. For the resultant vectors in part B, components are simply added or subtracted as appropriate. In part C, the vector equation aA + bB + C = 0 leads to two separate equations for the x and y components, which can be solved simultaneously. The equations derived are 6a - 8b + 26 = 0 and -8a + 3b + 19 = 0. This approach effectively addresses the problem's requirements.
joemama69
2. You are given three vectors: A = (6.0i— 8.0j) units B = (-8.0i + 3.0j) units and C = (26.0i + 19.0j) units.
a) Find the magnitude and direction of each vector.
b) Find the resultant of A + B, A - B and A + B - C.
c) It is know that aA + bB + C = 0. Find the values of a and b that satisfy this vector equation.
For part A, what does it mean to find the direction of each vector. do they want the angle
yes they do
I assume they want the angle of the vector. By convention, the angle is measured counter-clockwise from the positive x axis. Think of how you drew the unit circle in trigonometry.
For B, you simply add components.
Part C, you Have what appears to be one equation and two unknowns. However, it's a vector equation, which in your case is actually two equations. There's one for your x components and one for your y components.
so i would do
a(6.0i— 8.0j) +b(-8.0i + 3.0j) + (26.0i + 19.0j) = 0
6a - 8b + 26 = 0
-8a + 3b + 19 = 0 and just solve this system
Yes. Correct
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
