Find the minimal polynomial
Office_Shredder
Staff Emeritus
Find the minimal polynomial of \frac{\sqrt{3}}{1+2^{1/3}} over Q
we'll call this x
I wish I knew some :(
By taking powers of x, I was able to show that the extension Q(x) has degree six (since 21/3 and sqrt(3) are both independently inside Q(x)) and hence the minimal polynomial has degree six. So then I took a general degree six polynomial, plugged in x, and got six equations in six unknowns. This is less than elegant, and I ended with a system of equations (luckily three of the six unknown coefficients were zero):
255b + 261d + 595f = -171
150b + 222d + 460f = -144
105b + 159d + 375f = -108
solving for b,d,f. An attempt at a numerical solution doesn't convince me this has a rational solution, but I wouldn't be surprised if there was a computational error preceding this. Is there a better way to do this?
How about starting from the equation x=sqrt(31)+2^(1/3)? So (x-sqrt(31))^3=2. Expand the left side and move all of the terms involving sqrt(31) to one side and everything else to the other. Now square.
Sorry, you posted before I fixed the latex. Different value for x
EDIT: Same principle worked though. Thanks a ton
Fast, aren't I? Same idea. x=sqrt(3)/(1+2^(1/3)) -> x2^(1/3)=sqrt(3)-x. Cube, rearrange and then square.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
