Find the percentage increase in y
  • Thread starter Thread starter topsyturvy
    increase
When x is increased by 100%, it effectively doubles, leading to the equation y = k(2x)². This results in y being proportional to 4x², not 2x². The confusion arises from interpreting the percentage increase incorrectly; a 100% increase means adding the original value to itself. Thus, the correct approach is to substitute 2x into the original proportionality equation. The percentage increase in y, therefore, is 300%, as y increases from kx² to 4kx².
topsyturvy
y is directly proportional to x2.
x is increased by 100%.
Find the percentage increase in y.
so,
y=k x2
y= k (100 + x2)
then i went to find the k,
which is
k= y/ (100 + x2)
so i put back the k which i found into y= k (100 + x2)
which is :
y= y/(100 + x2) (100 + x2)
them I am stuck here..
somebody pls helppp!
thanks lotsa.:smile:
it should be 4x^{2} not x^{2} + 100
y= k (100 + x2)
x is increased by 100% just means that x has been doubled (i.e: 2x), and not 100 + x. Do you see why?
Consider the original amount (say b) to be 100%, so when increasing the original amount (i.e increase b) by 100% means that you add one more b to your original b, and get 2b, right?
So, can you go from here? :)
@courtrigrad: No, it should be 4x2, not 2x2. :smile:
EDIT: He did edit the post. Cheers. :)
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
