Find the potential fucntion, phi
  • Thread starter Thread starter Smazmbazm
    Phi Potential
Smazmbazm
Consider the vector field given by
F(x, y, z) = yz \hat{i} + xz \hat{j} + (xy + 3z^{2})\hat{k}
a. Calculate ∇xF and show that F is a conservative field. Done, result = <0,0,0> which implies the vector field is conservative.
b. The way we were taught this is to set
<br /> ∂\phi /∂x = yz, \\<br /> ∂\phi /∂y = xz, \\<br /> ∂\phi /∂z = xy + 3z^{2}<br />
Then find the integrals of all 3 equations to get,
<br /> \phi = xyz + C_{x},\\<br /> \phi = xyz + C_{y},\\<br /> \phi = xyz + z^{3} + C{z}<br />
Finally, look for similar features and construct \phi like so
\phi = xyz + x^{3} + C
Is that correct?
Is that really how you were taught? It will work but that "look for similar features" looks ambiguous to me.
In fact, in this particular problem, it is impossible to find such a \phi. It simply cannot exist.
Recall that (for "nice" functions, having continuous second derivatives as this does) the order of differentiation in mixed derivatives is irrelevant. That is \frac{\partial}{\partial x}\left(\frac{\partial\phi}{\partial z}\right)= \frac{\partial}{\partial z}\left(\frac{\partial\phi}{\partial x}\right)
But if \frac{\partial \phi}{\partial x}= yz then \frac{\partial}{\partial z}\left(\frac{\partial\phi}{\partial x}\right)= y while if \frac{\partial \phi}{\partial z}= xy+ 3x^2 then
\frac{\partial}{\partial x}\left(\frac{\partial\phi}{\partial z}\right)= y+ 6x.
Those are NOT the same so this is impossible. If that "3x^2" in the derivative with respect to z were "3z^2" then it would be possible.
Here's how I would do it.
From \dfrac{\partial \phi}{\partial x}= yz, yes we have \phi(x,y,z)= xyz+ u(y, z) where u(y,z) (your "C_x") is a function of y and z only (constant with respect to x). Differentiating that with respect to y we have
\dfrac{\partial\phi}{\partial y}= xz+ \dfrac{\partial u}{\partial y}
But we are told that \dfrac{\partial \phi}{\partial y}= xz so we must have xz+ \dfrac{\partial u}{\partial y}= xz. The "xz" terms cancel leaving \dfrac{\partial u}{\partial y}= 0 so that u does NOT, in fact, depend on y and we can write \phi(x, y, z)= xyz+ u(z). That is, we now know that u can only depend on z. Differentiating that with respect to z we get \frac{\partial\phi}{\partial z}= xy+ \frac{\partial u}{\partial z}.
But we are told that \dfrac{\partial \phi}{\partial z}= xy+ 3z^2. So we must have xy+ \frac{du}{dz}= xy+ 3z^2. The "xy" terms now cancel leaving \frac{du}{dz}= 3z^2. (I can now write "ordinary" derivatives because I know that u depends on z only.) That gives u(z)= z^3 so that \phi(x,y,z)= xyz+ u= xyz+ z^3.
If that "xy+ 3x^2" were, in fact, correct, here is what would happen. We would repeat everything up to the last paragraph which would now be:
" But we are told that \dfrac{\partial \phi}{\partial z}= xy+ 3x^2. So we must have xy+ \dfrac{du}{dz}= xy+ 3z^2. The "xy" terms now cancel leaving \dfrac{du}{dz}= 3x^2. That is impossible- if u is a function of z only, its derivative cannot be a function of x. There is no \phi(x,y,z) having those partial derivatives.
Thank you, good sir. That makes sense and seems slightly more intuitive than the method we were taught. This is a great explanation and it should hopefully help me for my examination tomorrow =/
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
