Find the rate at which water is draining from the tank after the following times.
In summary, Toricelli's Law gives the volume of water remaining in a tank after a certain amount of time, and the rate at which water is draining from the tank can be found using the chain rule. Specifically, V'(t) = 3500(2)(1-t/50)(-1/50). When plugged in with different values for t, the rate of draining can be determined, with the results being negative to reflect the decreasing amount of water in the tank.
Pondera
If a tank holds 3500 gallons of water, which drains from the bottom of the tank in 50 minutes, then Toricelli's Law gives the volume V of water remaining in the tank after t minutes as the following.
V = 3500 (1-t/50)^2 0 </=t<=50
Find the rate at which water is draining from the tank after the following amounts of time.
(a) 5 min
(b) 10 min
(c) 20 min
Basic knowledge of derivatives. The quotient rule?
I attempted to solve for V'(t).
V = 3500((1-(t/50)2)
V'(t) = 1(1-2t(2500)-t^2(1))/(2500)2
I then plugged in 5 for t = 5 and definitely got the wrong answer. The answer should be negative, since the water in the tank is decreasing, and it should be greatest at the smaller times since there is more water in the tank to leave it.
I factored out the equation so that V=3500(1-t/50)² becomes V=3500(1-2t/50+t²/2500)
Then I derived that to get: V'(t)=3500(-2/50+2t/2500)
Much easier than quotient rule, I think.
Then sub in your values and get negative results as required.
There is no need to use the quotient rule- there is no variable in the deominator: just the chain rule: V'= (3500)(2)(1- t/50)(-1/50).
And, redargon, you didn't "factor out" anything, you multiplied what was already factored.
ah, indeed. :shy:
1. What is the rate at which water is draining from the tank?
The rate at which water is draining from the tank refers to the volume of water that is leaving the tank per unit of time. It is typically measured in liters per hour or gallons per minute.
2. How do you calculate the rate of water draining from the tank?
The rate of water draining from the tank can be calculated by dividing the change in volume of water in the tank by the change in time. This is represented by the formula: rate = (V2 - V1) / (t2 - t1), where V1 and V2 are the initial and final volumes of water, and t1 and t2 are the initial and final times.
3. What factors affect the rate of water draining from the tank?
The rate of water draining from the tank can be affected by the size and shape of the tank, the size and shape of the outlet or drain, the pressure of the water, and the height of the water in the tank. Other factors such as temperature and viscosity of the water may also play a role.
4. How long does it take for the tank to drain completely?
The time it takes for the tank to drain completely depends on the rate at which water is draining from the tank and the initial volume of water in the tank. Using the formula rate = (V2 - V1) / (t2 - t1), the time can be calculated by rearranging the formula to t2 = (V2 - V1) / rate + t1.
5. Can the rate of water draining from the tank change over time?
Yes, the rate of water draining from the tank can change over time. It may decrease as the water level in the tank decreases, or it may increase if the outlet or drain becomes clogged. Other factors, such as changes in pressure or temperature, can also affect the rate of water draining from the tank.
