What is the Tension in a Rotating String?
  • Thread starter Thread starter Rohaaan
    String Tension
The discussion revolves around calculating the tension in a string attached to a rotating mass on a frictionless table. Given a mass of 1.00 kg, a string length of 40 cm, and a speed of 2.0 m/s, participants are prompted to apply relevant physics equations. Key equations mentioned include acceleration (a = v^2 / r) and force (f = ma). One participant initially expresses uncertainty about how to approach the problem but later confirms they figured it out. The conversation highlights the importance of understanding the forces acting on the rotating body to solve for tension.
Rohaaan
A body of mass 1.00kg is tied to a string and rotates on a horizontal, frictionless table. If the length of the string is 40cm and the speed of revolution is 2.0m/s, find the tension of the string.
a = v^2 / r
f = ma
v = 2∏rf
a = v^2 / r
f = ma
v = 2∏rf
Care to show us your attempts. ;)
What are the forces acting on the body?
I would attempt it, but I don't really know how to go about it. :(
Can you tell what forces are acting on the body?
Don't worry man, I just worked it out thanks. :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
