Find the total work done on 20.0N block
The discussion revolves around calculating the total work done on two blocks connected by a pulley system, specifically a 20.0N block moving horizontally and a 12.0N block moving vertically. Initially, the user incorrectly calculated the work done on both blocks as 0J due to misunderstanding the forces acting on them. After seeking clarification, it was suggested to consider the forces acting on each block without friction, which led to the user successfully recalculating the work done. The conversation highlights the importance of understanding the role of friction and the forces involved in the system. Ultimately, the user resolved their confusion and was able to complete the problem.
bharp24
Two blocks are connected by a very light string passing over a massless and frictionless pulley. The 20.0N block moves 75.0cm to the right and the 12.0N block moves 75.0cm downward.
Find the total work done on 20.0N block if there is no friction between the table and the 20.0N block.
Find the total work done on 12.0N block if there is no friction between the table and the 20.0N block.
Find the total work done on 20.0N block if static friction=0.500 and kinetic friction=0.325 between the table and the 20.0- block.
Find the total work done on 12.0N block if static friction=.500 and kinetic friction=.325between the table and the 20.0N block.
For the first two, I got total work done for both individual boxes to be 0J, but this is not correct somehow. I cannot really go on with the third and fourth scenarios until I get the first two. Can someone please help??
How did you determine this? What forces act on each block?
i think i went ahead and added a friction force into the first 2, which zeros them out. i still get a wrong answer though when I leave the friction out. any suggestions on how to complete this problem?
Start by answering my question: What forces act on each block?
i tried it again and got it right. thanks for trying to help me out!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
