Find the vertical distance between point, and quation?
  • Thread starter Thread starter nukeman
    Point Vertical
The discussion focuses on finding the vertical distance between the point A(−2,−3) and the line represented by the equation 2x + 5y = 3. The user attempts to convert the line equation into slope-intercept form, resulting in y = 2/5x - 3/5, and then plots the point and the line. They calculate the vertical distance using the distance formula, arriving at a value of 1.6, but express uncertainty about their arithmetic. Another participant suggests checking the calculations, indicating a possible error in the equation transformation. The conversation emphasizes the importance of accurate arithmetic and proper equation manipulation in solving the problem.
nukeman
What is the vertical distance between the point A(−2,−3) and the line 2x+5y=3.
Here is what I did: I know its wrong.
First, changed the equation into proper form:
y = 2/5x - 3/5
Plotted the equation...
Then, I drew in the point (-2,-3). Then drew line from point, vertically to the line, just as a graphical representation.
so from the line, x = -2
So, If x = -2, then y would equal -1.4
So, then I put this into the distance formula:
\sqrt{}(-2 - (-2))^2 + (-1.4 - (-3))^2
Which gave me 1.6
y = 2/5x - 3/5
Check your arithmetic right there.
Oh...
Is this correct then?
y = -2/5x + 3/5?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
