Find Time: Constant Acceleration
The discussion revolves around calculating the time taken to traverse a distance under constant acceleration, with specific parameters provided. The initial confusion stemmed from mixing up velocity and acceleration terms, but the correct approach involves using the equations of motion, particularly the average velocity formula and the relationship between final and initial velocities. The user refined their programming logic to accurately calculate elapsed time by applying different equations for the first and subsequent iterations. After several adjustments and validations against external calculators, the user successfully resolved their issues and gained a better understanding of the physics involved. The conversation highlights the importance of correctly applying physics equations in programming for accurate simulations.
attriola
Find the time it takes to traverse the distance.
Given:
*constant velocity
*initial acceleration = 0
*ending acceleration= 11176 m/s
*distance traversed = 28.96 km (18 miles)
velocity:
v^2 = v0^2 + 2a(delta x)
v = sqrt(v0^2 + 2a(delta x))
This isn't really a homework problem but this seemed the best place to ask the question.
I'm not a physics student, I tried looking up equations that might pertain but don't have the
background to hunt them down - I need this for a program I'm writing that gives the velocity
and distance at any point/time from lift-off under constant acceleration.
Most equations require <time>, which is what I don't know how to find.
Any help is most appreciated.
Tony
You have switched velocity and acceleration terms. It should be constant acceleration and initial and final velocities. And since you require time, use
delta[x]= u*t + 1/2a*t*t.
Thanks, your quite right, I did.
use: delta[x]= u*t + 1/2a*t*t.
Yes, I've since run into that on a thread-search and found a possible solution
suggested by Mike W, but tell me if I have it right:
Keeping in mind that beginning and ending velocities are known, distance is known,
and, as you pointed out, we have constant acceleration, it wouldn't seem much of a
stretch to determine average velocity, vF/2, in this case.
Determine average velocity (v~):
v~=(vF-vI)/2
Use the average velocity to solve for (t):
t=(delta[x]/v~)
And with (t) known, acceleration:
a=(vF-vI)/t
You think that will fly?
Thanks, aim, to both you and Mike W.!
Tony
Yeah I think that will fly.:smile:
Just keep in mind that this method works as long as acceleration is constant, and not for changing acceleration.
Thanks again aim, are you game for a follow-up?
In trying to calculate elapsed-time (say, for a mile), I noticed that it looked too high for the velocity I was logging.
(500 mph in 100 feet)
Using 'average' velocity each time through the loop, (t) is essentially static.
This didn't seem right as velocity increases considerably.
Then I tried 'average' velocity for just the first pass and vF thereafter, this gave me time-figures that looked more like what I expected.
However, not having any background in any of this, it's all just 'guesswork'.
( which is why I'm here...).
Commenting the if-else statement reverts to using 'average' velocity.
Help me understand which is the correct way to approach this.
No gravity, no atmosphere:
d: distance-feet (just for loop counting)
a: acceleration-m/s
t: time-sec
et: elapsed time-sec
vI: initial velocity-m/s
vF: final velocity-m/s
mps: miles per second
mph: miles per hour
Results:
Using: va=(vF-vI)/2.0; for each pass, t doesn't decrease.
Examp:
d=100 a=870.27 t=0.264663743325 et=0.2647 vI= 230.33 vF= 1100.60 0.66mps 2377.30mph
d=200 a=870.27 t=0.070046897031 et=0.3347 vI= 1100.60 vF= 1970.88 1.18mps 4257.10mph
d=300 a=870.27 t=0.070046897031 et=0.4048 vI= 1970.88 vF= 2841.15 1.70mps 6136.89mph
d=400 a=870.27 t=0.070046897031 et=0.4748 vI= 2841.15 vF= 3711.43 2.23mps 8016.68mph
d=500 a=870.27 t=0.070046897031 et=0.5449 vI= 3711.43 vF= 4581.70 2.75mps 9896.47mph
d=5300 a=870.27 t=0.070046897031 et=3.9071 vI=45484.58 vF=46354.86 27.81mps 100126.49mph
*et=3.9071*
Using: va=vF on all iterations other than the first 'looked' better.
Examp:
d=200 a=870.27 t=0.027693882030 et=0.2924 vI= 1100.60 vF= 1970.88 1.18mps 4257.10mph
d=300 a=870.27 t=0.015465187103 et=0.3078 vI= 1970.88 vF= 2841.15 1.70mps 6136.89mph
d=400 a=870.27 t=0.010728041621 et=0.3186 vI= 2841.15 vF= 3711.43 2.23mps 8016.68mph
d=500 a=870.27 t=0.008212475971 et=0.3268 vI= 3711.43 vF= 4581.70 2.75mps 9896.47mph
d=5300 a=870.27 t=0.000670117169 et=0.4109 vI=45484.58 vF=46354.86 27.81mps 100126.49mph
*et=0.4109*
Here's the loop:
double getET()
double sec,min,hrs,t,a,et,vF,vI,va,dx;
int i,d;
//loop - iterate through a given distance to find elapsed time
for (
i =0,
d =100,
dx =30.48, //100 ft.
et =0.0,
a =0.0,
vI =0.0,
vF =230.33; //500 mph
d<5400; //test: feet to run (approx 1-mile)
d+=100, //increment distance 100 feet
i++
//get avg velocity, 1st pass only
if(i==0)
va=(vF-vI)/2.0;
else
va=vF;
//increment elapsed-time
t=(dx/va);
et+=t;
//get acceleration, 1st pass only
if(i==0)
a=(vF-vI)/t;
//save current velocity then increment velocity
vI=vF;
vF+=a;
//output results
printf("d=%4d a=%6.2f t=%.12f et=%.4f vI=%8.2f vF=%8.2f - %5.2fmps %9.2fmph\n",
d, a, t,et, vI, vF,getmps(vF),getmph(vF));
return et;
You wrote vf+=a. As far as I see vf=v*at. Unless your time period is 1s this looks wrong to me. And please be more specific-my programming is not good anyways.
Try this and tell me what you get; but please no more program codes.:smile:
aim1732 said:
You wrote vf+=a. As far as I see vf=v*at...but please no more program codes.:smile:
My apologies, aim, I'll keep it descriptive (I hope).
The term vF+=a is a short form of vF=vF+a, (a) was previously calculated (just once).
Here's what the program does:
Initial velocity is defined as: 230.33 (500 mph), there is no need to calculate it since it's known.
Distance (and therefore dx) is defined as 30.48 m (100 ft), it doesn't change either.
I initially find the acceleration required to attain a velocity of 230.33 m/s in 30.48 m.
t=(dx/va)
a=(vF-vI)/t
That figure remains a constant since this is a constant-acceleration problem.
Having set all the initial values, whether by definition or calculation, I apply them on each iteration through the loop. The loop iterates in 30.48 (100 ft) increments.
I -thought- I could simply add the acceleration value to the previous velocity to obtain the current velocity (since we've traveled another 100 ft), but if I need to multiply that acceleration by time, then that is an issue I didn't see and, quite frankly, doesn't seem intuitive to me at the moment.
Here's why: time, in this case, is a function of velocity and not the other way around.
In this case, time seems to be a result rather than a parametric dependency of velocity.
In other words, velocity will always increment at a constant rate with only one dependency, acceleration. The time-measure will be the result of that acceleration added to velocity.
It also gets back to my original question: do I revert to using the average velocity calculation? You can see what happens when I do in result table #2, time doesn't change.
Maybe the problem is that I tend to see the issue in an iterative rather than an instantaneous sense, but that code certainly does seem to run-out correctly.
In any event, I certainly thank you for your patience, aim, I wish I was smarter and knew all about physics like you do, but as it is, I'd need several lifetimes to learn all I really want to know.
Tony
aim, I found my error (I think):
With time unknown:
vF^2 = vI^2 + 2a(sF-sI)
(source: http://en.wikipedia.org/wiki/Equations_of_motion)
I naively oversimplified the relationship...considerably! (although it still seems intuitively correct).
So now, I have to do this:
vF=sqrt(vI^2 + 2a(sF-sI))
in place of:
VF+=a
Pity. it seemed so 'right' at the time...
Does that look a little more palatable?
Thanks for putting up with me, aim, I'll probably be back with more queries, considering how much I don't know.
Tony
Hello attriola! First thing, there is no need to belittle yourself. Physics is one subject where nobody can claim to know everything.
Now the problem itself. There are three eqns. of motion:
vf = vi + at
delta x = vi*t + 0.5*a*(t^2)
vf^2 = vi^2 + 2a*delta(s)
You wrote the third but I would recommend the first. Your intution was right- velocity does increase by fixed amounts in a given time period- but that amount itself is dependent on the length of time period you choose. Here the length of your time period changes but you do have the variable t in the program code so the first eqn. seems to fit quite well, although the third eqn. is equally correct.
Hope this helps.
aim1732 said:
...but that amount itself is dependent on the length of time period you choose.
Thanks again, I came to that realization about 4:30 AM (pst), so got up to re-post but you beat me to it.
Of course, it makes sense on several levels. For one thing, I can't use (a) directly anyway, it's meaningless until multiplied by time.
In the code I posted, the only thing time was used for was to get the initial value for acceleration. Otherwise, it was just used to increment elapsed time.
However, since I didn't plug time into get velocity, everything was erroneous anyway.
I'll re-code this so it makes better sense and let you know how it went.
As i said, you're very gracious, aim, and I appreciate your indulgence.
Tony
aim, got it.
After several trials with either of the two forms of the equation, I came to the realization that the initial iteration requires this form of the equation:
vF=(a*t);
va=(vF-vI)/2.0;
t=(dx/va);
And the subsequent iterations require this form:
vF=sqrt((vI*vI)+((2*a)*(dx)));
t=(vF-vI)/a;
The reason is that on the first iteration, we know dx, vI and vF but not a or t.
On all other iterations, we know a, dx and vI, but not vF or t.
Mixing one with the other (including the time equation) just doesn't work.
Using the above forms also solved the problem with time not decrementing properly and invalid results.
I checked a sampling of results from a test-series I ran against a one-shot web-calculator here:
http://www.ajdesigner.com/constantacceleration/cavelocity.php
And they agree across the board, so I guess it's 'problem solved' and I learned a lot in the process.
Besides calculating elapsed time for a hypothetical constant-acceleration to cover a given distance, it let's me pick any number of terms and save the columns generated to a text file that I can import into a spreadsheet to generate a plot or simply write to a file that displays all the terms as they change, which is what I wanted.
In deference to your request, I won't post the code, but if you're ever interested, just drop me a line or PM.
Thanks again!
'Till next time,
Tony
Well done mate!
