Finding a constant of proportionality (Astro)
The discussion revolves around calculating the constant of proportionality, β, in the context of a galaxy's X-ray spectrum. Initially, there was confusion regarding the relationship between wavelength and frequency, leading to incorrect assumptions about the value of β. Through clarification, it was established that the correct transformation from wavelength to frequency results in β being equal to 2. The participants emphasized the importance of correctly expressing the relationship between F, λ, and ν to avoid confusion. Ultimately, the problem was resolved by accurately applying the proportionality rules and understanding the mathematical relationships involved.
lquinnl
OK so I'm doing a past exam paper as some revision:
The central galaxy in the Perseus cluster has an X-ray spectrum in wavelength units
which is well described by the power law
F_\lambda \propto \lambda^{-2} .
If the spectrum in frequency units is described by
F_v \propto v^\beta,
calculate \beta .
Obviously we have v = \frac{c}{\lambda}
so if v = \frac{c}{\lambda}
then does that mean that \beta = -3
I feel like I am really missing the point here. Any help would be greatly appreciated.
Thanks in advance!
How did you get -3?
Because lambda is to the power of -2 and lambda is related to frequency as v = c lambda^{-1} therefore adding an extra -1
does that make sense or is it total *@~% ?
I really cannot follow this logic. How does this "adding" come about?
Because
λ-1 λ-2 = λ-3
Am I on the right lines?
No, you are not. You really need to think how one could go from wavelength to frequency in a formula.
Looking at this again I am not convinced of my reasoning. I have this:
F_v \propto v^{-\beta} .
F_v \propto v^{-\beta} \propto {\frac{c}{\lambda}}^{-\beta} .
Any chance of a poke in the right direction, if you know?
You have a formula that contains \lambda^{-2}.
You need to express this formula via \nu. How would you do it?
F_\lambda \propto \lambda^{-2} \propto (v^{-1})^{-2} \propto v^{-3}
v \propto \lambda^{-1}
F_v \propto v^{\beta} \propto \lambda^{-1} \propto (v^{-3})^{-1} \propto v^{-4}
so \beta = 4
P.s. Thanks for all this help.
This part is correct.
But (\nu^{-1})^{-2} is NOT \nu^{-3}. I note that you made a similar mistake in another derivation. What is the proper result of such an operation?
OF COURSE! I feel so stupid today, really need to wake up!
(v^{-1})^{-2} = v^{2}
so
F_v \propto v^{\beta} \propto \lambda^{-1} \propto (v^{2})^{-1} \propto v^{-2}
and
\beta = 2
Am I Right?
Or have I messed up still, regarding a sign?
This is correct. But what you do then puzzles me. You have just proved that since
\lambda^{-2} \propto \nu^{2}
we have
F \propto \lambda^{-2} \propto \nu ^{2}
What I'm saying is that
F_\lambda \propto \lambda^{-2} \propto v^{2}
from v = \frac{c}{\lambda} we have v \propto \lambda^{-1}
so
F_v \propto \lambda^{-1}
now i think maybe this should be how i follow:so
F_v \propto v^{\beta} \propto (\lambda^{-1})\propto(v^{2})^{-1}
Again, you just got the expression in terms of v^{2}. While you know it should be in terms of v^{\beta}. What does this mean to you?
So if F_v \propto v^{\beta} \propto v^{-2}
\beta = -2
Why is this MINUS 2? Just two messages above it was PLUS 2.
I thought it should be minus 2 from this statement:
F_v \propto v^{\beta} \propto (\lambda^{-1})\propto(v^{2})^{-1}[/QUOTE]
I think you are very confused. Let me explain the whole thing to you.
When something (A) is proportional something else (B), then A = CB, where C does not contain B in any way.
In your case, you have F proportional to \lambda^{-2}, which means F = k\lambda^{-2}
You are asked to find out to what degree of \nu that is proportional. This is done by expressing \lambda via \nu, which is \lambda = c\nu^{-1}, so you end up with F = k(c\nu^{-1})^{-2} = kc^{-2}\nu^{2}, which simply means that F \propto \nu^{2} and \beta = 2.
THANK YOU VERY MUCH!
I feel like I have done an incredible job of over-complicating this problem!
I think I was getting confused by the fact we have F_v and F_lambda.
So it was just a case of expressing wavelength as frequency and amalgamating the powers.
Seems incredibly straightforward now!
Thanks again
