Finding a Non-Diagonalizable 3x3 Matrix with 2 as its Only Eigenvalue
tengxiaona
Find a 3*3 matrix A which is not diagonalizable and such that 2 is the only eigenvalue of A
since λ=2,and it is a 3*3 matrix
i get the det(λI-A)=(λ-2)^3=0
then λ^3-6λ^2+12λ-8=0
now i use http://image.cramster.com/answer-board/image/cramster-equation-2009452223286337456700835550002161.gifas[/URL] matirx A
and i calculate
det(λI-A)
=λ^3-λ^2(i+e+a)+λ(ai+ae+ie-cg-hf-bd)-(aef+bfg+cdh+cge-ahf-bdi)=0
now we can easy to know that
i+e+a=6
ai+ae+ie-cg-hf-bd=12
aef+bfg+cdh+cge-ahf-bdi=18
now I am stuck here
can anyone help me to slove these equtions.
i don't konw the way i doing this problem is right or wrong.
if u have any others ideas,please help me
There are infinitely many solutions to those equations: 9 variables and 3 equations. Also, solutions to them tell you nothing about whether or not the matrix can be diagonalised. You're going to have to think of a different method.
Do you know of any other forms a matrix can be put into if it is not diagonlisable?
Do you know of any matrices where it is easy to see what the eigenvalues are?
sorry, i don't have any ideas
could u just give me any hints?
Hint: think about upper triangular matrices.
but the matrix A is not diagonalizable
Do you really think all upper triangular matrices are diagonalizable?
ok,i trid again and stuck again
i set A as
a b c
0 d e
0 0 f
use the way i did before above
finally i get
a+d+f=6
fd+af+ad=12
adf=18
then....=.=
i still can't slove these equtions
Dick , wut exactly do u mean by ues an upper matrix
By an upper triangular matrix I mean exactly what you posted. You should be able to tell me what the eigenvalues of that matrix are without working too hard. That tells you what values a, d and f should have. Now you just want to find an EXAMPLE of values of b, c and e that is NOT diagonalizable. Hint: it's not diagonalizable if you can't find three linearly independent eigenvectors. Just try guessing. Hint: b=c=e=0 is a bad guess.
Where did those 3 equations come from, and why? I think you need to work out the determinant of an upper triangular matrix again. You still haven't addressed what it means for a matrix to be (or not be) diagonalizable, either.
i got it now !
i really went to a wrong way!
thanks for DICK and MG you guys help!
