Finding Acceleration Of A Bucket Moving Downwards With A Pulley
  • Thread starter Thread starter Lost_Prophet75
    Acceleration Pulley
The discussion focuses on calculating the acceleration of a system involving a 26.5 kg block and a 1.00 kg bucket connected by a cord over a frictionless pulley. The user has determined that 10.528 kg of sand must be added to the bucket to initiate movement, but struggles with setting up the equations for tension and acceleration. Key equations derived include T = μN + ma for the block and T = mg + ma for the bucket. The solution involves first calculating the acceleration of the system and then using that value to find the tension in the cord.
  • Understanding of Newton's laws of motion
  • Familiarity with free-body diagrams
  • Knowledge of static and kinetic friction coefficients
  • Basic algebra for solving equations
  • Study the principles of Newton's second law in multi-body systems
  • Learn how to apply free-body diagrams to complex pulley systems
  • Explore the effects of friction on motion in physics
  • Review the concept of tension in strings and cords in mechanics
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators looking for examples of pulley systems and friction analysis.
Lost_Prophet75
A 26.5 kg block is connected to an empty 1.00 kg bucket by a cord running over a frictionless pulley (Fig. 4-57). The coefficient of static friction between the table and the block is 0.435 and the coefficient of kinetic friction between the table and the block is 0.320. Sand is gradually added to the bucket until the system just begins to move.
So far I have solved the mass of the sand added to the bucket, which is 10.528kg, ignoring the mass of the bucket. I am still unsure of how to setup the equation, because I am confused on what I use for tension. The tension I originally used should have changed due to the mass of the sand now added to the bucket. The first time I solved for tension, I didn't need acceleration, as the bucket was at rest. Every equation I try to set up comes out needing two variables, neither of which I have any idea how to solve for.
When I try to find tension, my equation comes out to one of these two (Sorry if I write these wrong, still figuring out how to type out an equation).
For the Tension in the block, i get T=[tex]\mu[/tex]N + ma, which requires the use of either tension or acceleration to solve. I got this equation by using a free-body diagram, which had weight going down the y-axis, normal force going up the y-axis, tension to the right on the x-axis, and Friction going left on the x-axis. The sum of my forces would then be Tension minus friction equals mass times acceleration, so I moved friction over, and converted it to mu times normal force.
My Other equation is for the bucket, which is T=mg +ma. For this one, ny free body has two forces acting on it, both on the y-axis. Tension going up, weight moving it down. My sum of forces came out to be Tension minus weight equals mass times acceleration.
What am I missing here, or am I over complicating things? :confused:
Ok, If I'm understanding what it is you're trying to solve for, it is the tension in the line between the two blocks. You have already correctly calculated the additional sand mass that must be added into the bucket to overcome the static friction, so we are now working with a kinetic friction acting on the block located on the table.
To get to the tension, you first want to solve for what the acceleration of the two bodies is together (this can be done without breaking it down into separate free body diagrams knowing that the tension in the line must be constant). You can then use that acceleration and go back to the free body diagram of either block to solve for the tension in the cord.
This is my first post on here and I'm not too sure of how much information is normally given (I don't want to just hand the solution over). I hope this can at least send you in the right direction. Let me know if you need more help.
  • · Replies 23 ·
  • · Replies 18 ·
  • · Replies 22 ·
