Finding angular acceleration for this prob
To find the constant angular acceleration of a rotating wheel that completes 37 revolutions in 3.00 seconds with a final angular velocity of 98.0 rad/s, the initial angular velocity must be calculated first. The average angular velocity can be determined using the formula for angular displacement over time, leading to the calculation of the initial angular velocity. Once the initial velocity is established, the angular acceleration can be derived using the equation that relates initial and final angular velocities with time. The correct approach yields an angular acceleration of approximately 13.7 rad/s², confirming the expected answer. This method integrates all relevant parameters into a single formula for efficiency.
ballahboy
A rotating wheel requires 3.00s to rotate 37.0 revolutions. Its angular velocity at the end of the 3.00-s interval is 98.0rad/s. What is the constant angular acceleration of the wheel?
What i did was i used average w=delta(theta)/delta time. Then i used average w=radical(w^2+wo^2) to find wo. Then i plugged it all into w=wo+alpha(t) and i got alpha=12.67. The answer is suppose to be 13.7rad/s^2. Can someone help me on this problem?
thanks
There is a single formula, incorporating all the elements you are given: wf, t, theta, alpha. Find that, and just sub in values.
What is the formula? The ones I have all have "wi" in it and I'm not sure I calculated that correctly.
Here's how you calculate the initial angular velocity.
Since angular acceleration is constant:
\frac{\Delta\theta}{\Delta t}=\omega_{av}=\frac{\omega+\omega_{0}}{2}
Since one revolution is 2\pi radians,
2\times\frac{37\times 2\pi}{3 s}-98.0\frac{rad}{s}=\omega_{0}
Now use \omega=\omega_{0}+\alpha\Delta t
That method works, as does using: theta = (wf)t - .5*alpha*t^2.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
