How Do You Calculate Angular Distance and Displacement in Biomechanics?
  • Thread starter nsxviper
  • Tags
    Angular
In summary, the tennis player takes 3 preparatory swings with each swing traveling through an arc of 140 degrees. The 4th swing, where the ball is struck, travels through an arc of 240 degrees. To calculate the total angular distance and displacement of the club, we can use the formulas for tangential acceleration, velocity, and distance, substituting α for a, ω for v, and θ for s.
nsxviper
A tennis player takes 3 preparatory swings, each swing travels through an arc of 140 degrees each way. At the 4th swing, the ball is struck and the swing travels 240 degrees. Calculate the total angular distance and angular displacement of the club.
I have no clue, is it theta = d/r ?
I am so confused because all I am given is the arc and no radius. Is the angular distance in rads or meters? I can't seem to find the formula for this. I've taken physics and I know how to solve for angular velocity and angular acceleration but never did solve for angular distance. This is for my biomechanics class.
Welcome to PF!
Hi nsxviper! Welcome to PF! :smile:
nsxviper said:
… I've taken physics and I know how to solve for angular velocity and angular acceleration but never did solve for angular distance.
Since you obviously understand the difference between angular velocity and ordinary velocity, and between angular acceleration and ordinary acceleration, just go with the flow :wink: … the difference between angular distance and ordinary distance is exactly the same. :smile:
a (tangential) = rα
v (tangential) = rω
s (tangential) = rθ
(and so, for example, if you've done the standard constant acceleration equations, v = u + at etc, you can apply them to constant angular acceleration, just substituting α for a, ω for v, and θ for s)
I can provide a response to this content by first clarifying that angular distance is measured in radians, not meters. The formula for angular distance is indeed theta = d/r, where d is the arc length and r is the radius. In this case, since the arc length and radius are not given, we cannot calculate the exact value of the angular distance. However, we can still calculate the total angular distance and angular displacement of the club by using the given information.
To find the total angular distance, we can add up the angular distances of each swing. In this case, the first three swings each travel through an arc of 140 degrees, so the total angular distance would be 140 + 140 + 140 = 420 degrees. This is equivalent to 7π/3 radians.
To find the angular displacement, we need to calculate the difference between the final position of the club and its initial position. In this case, the club starts at 0 degrees and ends at 240 degrees, so the angular displacement would be 240 - 0 = 240 degrees. This is equivalent to 4π/3 radians.
In summary, the total angular distance of the club is 420 degrees or 7π/3 radians, and the angular displacement is 240 degrees or 4π/3 radians. It is important to note that the units for angular distance and angular displacement are in radians, not degrees.
What is angular distance?
Angular distance is the measurement of the separation between two points on a sphere, such as the sky. It is usually measured in degrees, minutes, and seconds.
How is angular distance different from linear distance?
Angular distance is measured along a curved surface, such as a sphere, while linear distance is measured in a straight line. This means that angular distance takes into account the curvature of the surface, while linear distance does not.
What is the formula for calculating angular distance?
The formula for calculating angular distance is: angular distance = arc length / radius. The arc length is the length of the curved path between the two points, and the radius is the distance from the center of the sphere to the points.
What are some common units of measurement for angular distance?
The most common units of measurement for angular distance are degrees (°), minutes ('), and seconds (''). These units are also used for measuring time and are based on a sexagesimal system, which means there are 60 minutes in a degree and 60 seconds in a minute.
How is angular distance used in science?
Angular distance is used in various fields of science, such as astronomy, geology, and geography. It is particularly useful in calculating the positions of celestial objects, measuring distances on Earth's surface, and mapping out geological features. It is also used in navigation and surveying.
